Tidal playlists loading issue
Hi all,
I have found another weird situation with AS and Tidal.
When using the AS app on my Mac, I can see al my Tidal playlists but when I try to open one it won’t load the songs within that playlist.
Strangely, I can use the remote app on my iPhone to open and play the playlist and can select any song from the playlist without a problem.
Is this a known bug? If so, any fixes?
Hi @JB92,
Can you send us a copy of the "Debug Infoā€œ when you have this issue? You can get it in Audirvana Settings>My account.
Note: By clicking on the Debug Info button, Audirvana automatically copies all its content. All you have to do is paste it in response to this message
Sure thing @Antoine, here you go.
I will add that
  1. I haven’t been able to open one of my personal playlists for a few weeks now, other than from the remote app. It worked perfectly for a while.
  2. Opening a Tidal curated playlist works fine.
Audirvana Studio 2.7.0 (20700)
macOS Version 13.0 (Build 22A380) with 8GB physical RAM
Connected account of : Jacques Booyens
Effects plugins ACTIVE in offline mode with legacy macOS API
	AU plugin #0: Music Effect - MeldaProduction MConvolutionEZ ()
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
SW volume control: ON
AUTO: /Users/jacquesbooyens/Library/Mobile Documents/com~apple~CloudDocs/Music/Collection
iTunes/Music library synchronization: last synchronized on Fri Feb 2 17:40:01 2024
Library database path: /Users/jacquesbooyens/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 1093
Listening on 127.0.0.1 on port 50982
TIDAL: Connected as HiFi Plus
Active method: UPnP
Preferred device: [UPnP] Living Room Model UID:Linkplay Technology Inc. WiiM Pro-4E82 UID:uuid:FF98F09C-C6DB-EC21-B9CD-01F2FF98F09C
Selected device:Living Room
Manufacturer: Linkplay Technology Inc.
Model name: WiiM Pro-4E82
Model UID: Linkplay Technology Inc. WiiM Pro-4E82
UID: uuid:FF98F09C-C6DB-EC21-B9CD-01F2FF98F09C
UPnP device at http://192.168.3.14:49152/description.xml
ID 0x0
Volume control: Yes
Max volume alert: Disabled
Unhandled (PCM conversion) with boost gain of 0dB
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: Yes
Unwanted playback stop workaround: Yes
http-get::audio/wav:DLNA.ORG_PN=LPCM
http-get:
:audio/x-wav:DLNA.ORG_PN=LPCM
http-get:
:audio/mpeg:DLNA.ORG_PN=MP3X
http-get:
http-get:
:audio/mpeg:DLNA.ORG_PN=MP2_MPS
http-get::audio/mp3:
http-get::audio/wma:
http-get::audio/mpeg:
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get::audio/m4a:DLNA.ORG_PN=AAC_ISO
http-get:
:audio/aac:DLNA.ORG_PN=AAC_ISO
http-get::audio/ac3:DLNA.ORG_PN=AC3
http-get:
:audio/ogg:*
http-get::audio/ape:
http-get::audio/x-ape:
http-get::audio/flac:
DLNA 1.5: Yes
Native Gapless playback: Yes
Universal Gapless playback active: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI: optical
CurrentURIMetadata: <?xml version="1.0" encoding="UTF-8"?>
song:subid</song:subid>
song:description</song:description>
song:id0</song:id>
song:coding_fLPCM</song:coding_f>
song:singerid0</song:singerid>
song:albumid0</song:albumid>
optical
dc:title</dc:title>
dc:creator</dc:creator>
upnp:artist</upnp:artist>
upnp:album</upnp:album>
upnp:albumArtURI</upnp:albumArtURI>
nextURI:
nextURIMetadata:
PlayMedium: OPTICAL
Current transport actions:
Play,Stop
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Living Room Linkplay Technology Inc. https://wiimhome.com WiiM Pro Receiver WiiM Pro Receiver https://wiimhome.com uuid:FF98F09C-C6DB-EC21-B9CD-01F2FF98F09C V01-Feb 1 2024 00001 WiiM Pro-4E82 FF98F09CC6DBEC21B9CD01F2 QPlay:2 image/png 48 48 24 /upnp/grender-48x48.png image/png 120 120 24 /upnp/grender-120x120.png image/jpeg 48 48 24 /upnp/grender-48x48.jpg image/jpeg 120 120 24 /upnp/grender-120x120.jpg urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 urn:schemas-wiimu-com:service:PlayQueue:1 urn:wiimu-com:serviceId:PlayQueue /upnp/PlayQueueSCPD.xml /upnp/control/PlayQueue1 /upnp/event/PlayQueue1 urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /upnp/QPlaySCPD.xml /upnp/control/QPlay1 /upnp/event/QPlay1
UPnP devices found : 1
Device #0: ID 0x0 : Living Room
Max. memory for audio buffers: 4170MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Device #0: ID 0x45 MacBook Air Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. MacBook Air Speakers
Device #1: ID 0x51 ZoomAudioDevice
Manufacturer: zoom.us
Model UID: zoom.us.zoomaudiodevice
UID: zoom.us.zoomaudiodevice.001
Model name: zoom.us ZoomAudioDevice
Chromecast devices found : 1
Device #0: Living Room
Model name: WiiM Pro Receiver
what happens when you try to open it, do you see the content in the playlist?
No @Antoine, nothing at all.
Here is the desktop app:
…and here is the mobile app:
Also worth pointing out is that the desktop app takes ages to load the playlists (at least 5 seconds per playlist). When opening the playlist I get the rainbow wheel on my Mac for a good few seconds before it opens the playlist, only to not load any tracks.
Can you share the playlist so I can try to reproduce your issue on my side?
https://www.hardreset.info/devices/apps/apps-tidal/share-playlist/
@Antoine, it happens on literally every playlist that I have…
Hi @JB92,
Have you tried to disconnect and reconnect your Tidal account from Audirvāna Studio?
Hi @Antoine,
Yes, that was the first thing that I tried to do and repeated when I installed the new version.
Another interesting quirk to this bug:
  1. Open AS on MacBook
  2. Attempt to open playlist - doesn’t work
  3. Open playlist on phone - works
  4. Choose first track on playlist from phone and play
  5. Open queue on MBP - all songs in playlist are visible
When I go to Tidal → My Music → My Playlists, I see all the Playlists that I created in the Tidal Application on my MAC.
However, all the playlists show their titles and Album Collage but NO tracks are listed in ANY of the playlists.
I have shutdown Audirvana, logged/logged back out. It shows the Playlists BUT no tracks in any of them :frowning:
What am I missing? Please see attached screenshot.
Hi @Spiritual-Abies-2600,
Does it work if you try to access this playlist using the remote?
I have never used the remote functionality, so not sure. I shall download the remote app and report back.
Okay, here is an update… After using the Remote Application, I saw the following behaviour.
  • The Playlists that are coming up 1st are simply put as ā€œMusicā€ title header. In the Remote App, these same playlists are put under the ā€œAppleā€ tab. I no longer have Apple Subscription, so not sure how or why these lists are showing up?
  • Then there is ANOTHER playlist tab, called Tidal, in the remote App. If I play those, they all work. Going back to the Desktop version, if I scroll past the non-working ā€œMusicā€ titled playlists I can get to the Tidal playlists and they work.
So questions, how do I remove the ā€œAppleā€ Music playlists since they don’t work. Also I cancelled my Qobuz account, but now every startup it is saying it has issues logging into Qobuz, but when I go to settings > streaming, it shows ā€œdisconnectedā€ under Qobuz
You must go to Audirvāna settings under the LOCAL section and remove the iTunes/Musci sync.
About Qobuz, can you disconnect and then reconnect your account? To do this, you must go to Audirvāna settings, My Account section.
@Antoine just an update here.
  1. I am still experiencing the same problem here.
  2. Remote app still solves the problem
  3. I accidentally opened the old Audirvana app (Classic?) and it loaded my playlists without a problem.
Is there any news that could be shared re this bug? Possibly the team is working on resolving this?
Which Mac are you using? Is it an Apple Silicon?
Yes, M1
