I would like to have my promotion code reset. Tidal support requests me to do so as follows. Please respond.
Thank you,
I tested the code XXXXXXXXXX and it shows invalid, this means you will have to contact Audirvana so they can issue a different code or link.
Is there anything else I may assist you with?
Can you reset this code?
Unfortunately we cannot reset codes here at TIDAL support.
You will have to reach out to Audirvana
