I have a new EarMen Sparrow DAC plugged in with Tidal streaming through Audirvana on a Windows 10 Laptop.
I mainly listen to MQA Master files. The volume appears to be at a fixed level. No pressing of + or - or sliding of the bar works affects the sound level. Computer volume, mute etc has no affect.
What am I missing with the setup? Are my settings correct?
I have posted the debug file below so any help would be much appreciated. Thanks.
Audirvana Studio 1.12.2 (11202)
Windows 10 (19044) with 32GB physical RAM
Max allowed volume: 54.2857
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\trevo\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.20.11 on port 64789
Max. memory for audio buffers: 10272MB
Local Audio Engine: WASAPI
Speakers (EarMen Sparrow)
Model UID:MMDEVAPI\AudioEndpoints
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{98fc0cd0-59ee-40dc-9f96-dfbf6f38e852}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 24bits Integer, 6 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Manufacturer: Microsoft
Model Name: Speakers (EarMen Sparrow)
Model UID: MMDEVAPI\AudioEndpoints
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{98fc0cd0-59ee-40dc-9f96-dfbf6f38e852}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
MQA Renderer device
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Device #0: Speakers / Headphones (Realtek Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{88d1cab7-5afe-444a-b39d-2a70cdd7f66d}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Speakers / Headphones (Realtek Audio)
Device #1: Speakers (EarMen Sparrow) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{98fc0cd0-59ee-40dc-9f96-dfbf6f38e852}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Speakers (EarMen Sparrow)
