Nope, Audirvana will only do the first unfold. For the rest you need an MQA enabled DAC.
Just set the auto-detect MQA to off and manually set to “non MQA”. Whether it will be better than Qobuz depends on the subscription you have with both services, and what you make of the MQA.
I have the highest fidelity for both Qubuz and Tidal. So with that setting tidal should be comparable to Quobuz, and the difference in sound will be subtle?
