I’m using the very nice Audirvana’s Recommended option [CONNECTED > TIDAL > New > Albums > Recommended] a lot (inside Tidal it’s called ‘Suggested Albums for You’ or 'Suggested New Albums). But it is not updating anymore. The ‘recommendations’ in Audirvana are ‘old’ and not in sync with Tidal’s recommendations as it was before. Even if I disconnect and reconnect Tidal from within Audirvana… even then the old recommendations are presented.
Can I fix this myself or is it a ‘bug’?
