I experienced this several times since update to 2.6:
- I power on my second system
- I select the DAC in AS
- I try to play a track: no sound but playing speed is abnormal (Too fast).
- Only solution: power recycle the DAC.
Here is a log (Play a track, and then stop playing):
2023-11-24 15:22:47.419 [debug]: UPnP Received AVTransportURI change to http://192.168.1.16:49152/audirvana/audio_f_6.wav
2023-11-24 15:22:47.419 [debug]: UPnP AVTransportURI change notification DISCARDED as in starting phase
2023-11-24 15:22:47.419 [debug]: UPnP Received updated transport actions:Next,Previous,Play
2023-11-24 15:22:47.437 [debug]: UPnP setPlayingBuffer discarded
2023-11-24 15:22:47.445 [debug]: UPnP Received new transport state STOPPED
2023-11-24 15:22:47.471 [debug]: UPnP Success setting AVTransportURI to http://192.168.1.16:49152/audirvana/audio_f_8.wav
2023-11-24 15:22:47.476 [debug]: UPnP Received AVTransportURI change to http://192.168.1.16:49152/audirvana/audio_f_8.wav
2023-11-24 15:22:47.476 [debug]: UPnP AVTransportURI change notification DISCARDED as in starting phase
2023-11-24 15:22:47.478 [debug]: UPnP Send info for file audio_f_8.wav from buffer 0 trackId 8
2023-11-24 15:22:47.478 [debug]: UPnP open file /audirvana/audio_f_8.wav
2023-11-24 15:22:47.478 [debug]: UPnP sent WAVE header with fileLength 69862844 audio data 69862800 from buffer 0 trackId 8
2023-11-24 15:22:47.478 [debug]: UPnP received audio data request from 0 for 1048532 loaded 5760000 from buffer 0 trackId 8
2023-11-24 15:22:47.478 [debug]: UPnP sending audio from 0:0 playing 0:0 loaded to 0:10 from 0 for 1048532 requested 1048532 loaded 5760000 from buffer 0 trackId 8
2023-11-24 15:22:47.581 [debug]: UPnP received audio data request from 1048532 for 1048576 loaded 20160000 from buffer 0 trackId 8
2023-11-24 15:22:47.581 [debug]: UPnP sending audio from 0:1 playing 0:0 loaded to 0:35 from 1048532 for 1048576 requested 1048576 loaded 20160000 from buffer 0 trackId 8
2023-11-24 15:22:47.699 [debug]: UPnP received audio data request from 2097108 for 1048576 loaded 37440000 from buffer 0 trackId 8
2023-11-24 15:22:47.699 [debug]: UPnP sending audio from 0:3 playing 0:0 loaded to 1:5 from 2097108 for 1048576 requested 1048576 loaded 37440000 from buffer 0 trackId 8
2023-11-24 15:22:47.819 [debug]: UPnP received audio data request from 3145684 for 1048576 loaded 57600000 from buffer 0 trackId 8
2023-11-24 15:22:47.819 [debug]: UPnP sending audio from 0:5 playing 0:0 loaded to 1:40 from 3145684 for 1048576 requested 1048576 loaded 57600000 from buffer 0 trackId 8
2023-11-24 15:22:47.944 [debug]: UPnP received audio data request from 4194260 for 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:47.944 [debug]: UPnP sending audio from 0:7 playing 0:0 loaded to 2:1 from 4194260 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:48.332 [debug]: UPnP received audio data request from 5242836 for 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:48.332 [debug]: UPnP sending audio from 0:9 playing 0:0 loaded to 2:1 from 5242836 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:48.424 [debug]: UPnP received audio data request from 6291412 for 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:48.424 [debug]: UPnP sending audio from 0:10 playing 0:0 loaded to 2:1 from 6291412 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:48.485 [debug]: UPnP Received updated transport actions:Next,Previous,Pause,Stop,Seek
2023-11-24 15:22:48.486 [debug]: UPnP Received new transport state PLAYING
2023-11-24 15:22:48.486 [debug]: UPnP Set next Chunk playing 9 for buffer 1 starting at 0
2023-11-24 15:22:48.496 [debug]: UPnP Exiting playing start polling loop with 45 attempts remaining
2023-11-24 15:22:48.508 [debug]: UPnP Success setting NextAVTransportURI to http://192.168.1.16:49152/audirvana/audio_f_9.wav
2023-11-24 15:22:48.823 [debug]: UPnP received audio data request from 7339988 for 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:48.823 [debug]: UPnP sending audio from 0:12 playing 0:10 loaded to 2:1 from 7339988 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:48.904 [debug]: UPnP received audio data request from 8388564 for 1048576 loaded 698628
2023-11-24 15:22:48.905 [debug]: UPnP sending audio from 0:14 playing 0:10 loaded to 2:1 from 8388564 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:48.994 [debug]: UPnP received audio data request from 9437140 for 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:48.994 [debug]: UPnP sending audio from 0:16 playing 0:10 loaded to 2:1 from 9437140 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:49.080 [debug]: UPnP received audio data request from 10485716 for 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:49.080 [debug]: UPnP sending audio from 0:18 playing 0:10 loaded to 2:1 from 10485716 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:49.153 [debug]: UPnP received audio data request from 11534292 for 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:49.153 [debug]: UPnP sending audio from 0:20 playing 0:10 loaded to 2:1 from 11534292 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:49.851 [debug]: UPnP Success sending Pause request
2023-11-24 15:22:50.322 [debug]: UPnP received audio data request from 12582868 for 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:50.322 [debug]: UPnP sending audio from 0:21 playing 0:20 loaded to 2:1 from 12582868 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:50.499 [debug]: UPnP Received updated transport actions:Next,Previous,Play,Stop,Seek
2023-11-24 15:22:50.500 [debug]: UPnP Received new transport state PAUSED_PLAYBACK
2023-11-24 15:22:50.662 [debug]: UPnP Exiting playing start polling loop with 46 attempts remaining
2023-11-24 15:22:50.739 [debug]: UPnP received audio data request from 13631444 for 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:50.739 [debug]: UPnP sending audio from 0:23 playing 0:20 loaded to 2:1 from 13631444 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:51.073 [debug]: UPnP received audio data request from 14680020 for 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:51.073 [debug]: UPnP sending audio from 0:25 playing 0:20 loaded to 2:1 from 14680020 for 1048576 requested 1048576 loaded 69862800 from buffer 0 trackId 8
2023-11-24 15:22:52.505 [debug]: UPnP Received updated transport actions:Next,Previous,Play
2023-11-24 15:22:52.505 [debug]: UPnP Received new transport state STOPPED
