I’ve recently decided to use Audirvana. I have downloaded and installed the app and I think it sounds great but I’m having problems with too many duplicate albums/tracks.
I’ve now gone right through my mac and deleted any duplication of files that I can find. I’ve moved all music files into my iTunes Media/Music folder and now there is only one file of each album with no duplications within the file. I’ve told Audirvana where to look for my music and relaunched it only to find I’m still getting duplicate albums in the list.
in my experience the database is a little picky, you have to treat it gracefully … and be patient
Start from scratch if you can, delete the db and reinstall the application, then configure the watched folders and let it work until synchronization will end, this is fundamental.
And to add a new album
close Audirvana
Copy the new album in the watched folders
restart Audirvana and wait until synchronization will end
If you follow this “guideline” you should not face this issue anymore
I’ve closed down the app. Made sure the Monitored Folder is correct. Gone to the 2nd Method of synchronisation and selected it. Left it to synchronise. Shut it down and restarted the app only to find more duplications than I started with, three in some cases.
I know for sure that all my music files are in one folder so what is going on.
Start from scratch is to say uninstall Audirvana, delete the db located in Users/your-user/Library/Application Support/Audirvana
The file type is .sqlite
Then install again Audirvana ecc…
Update . . . I’ve realised that the Library folder is hidden. I now revealed it and done as you said and deleted the .sqlite file from Audirvana. I have now reinstalled and shown it where the files are and it is now synchronising. I’ll let you know how it goes . . . thanks for the help.
if you add the artwork in iTunes they are not embedded in the file but stored in a cache, then they are not available outside iTunes. You’ll have to add them again in Audirvana or using a tag editor (I use Yate)
