Hi,
I somehow managed to forget to deactivate my Audirvana license. Now I’m unable to activate the program again. Also, I’m rather sure that there should be one free activation left.
Please advise.
Thank you in advance,
Jan
Hi,
Please advise.
Jan
Hello @gizka,
I have removed all your computers from the license database.
You can now activate up to two PC running Windows 10.
To install Audirvana on your PC, you can proceed as follows:
Hi Damien3,
many, many thanks. Registration worked flawlessly.
Regards,
Jan (gizka)
Add me to this issue as I had one computer with a logic board failure and the backup is now showing unregistered.
So the computer I’m using says I’ve exceeded the allowance. I can’t “deauthorize this computer” on the other laptop now my backup running a copy of my hard drive.
My license ends with X1
Thanks.
Regards,
Roman
Hello Damien,
I had a harddrive damage and couldn`t deactivate my license. The software is not running on any other computer.
Can you support me with that issue.
Thank you
Karsten
Hello @KarstenH,
Thank you Damien,
it was working.
Regards
Karsten
Bonjour Damien
Mon précédent HDD a grillé, je ne peux donc pas réinstaller Audirvana.
Merci de m’aider
Bonne journée
I get the “too many installs” also after re installing win10. Can you please remove my computers from the database. Thx!
