I installed linux on the computer on which I had previously been using Audirvana. I failed to deactivate my Audirvana license on that computer before I wiped out Windows. Now, when I try to install Audirvana on a different Windows computer, I get the “too many installations” error message. Could you please reset my registration?
Same thing for me. I tried Fidelizer Pro 8.5 and it doesn’t work with Audirvana. it caused a lot of problems. Now, I don’t see music library progress bar, when I scan my music library, and my cd covers when I play a music files. Unfortunately, I think I have to reset or wiped my Windows 10 Pro. Can you please reset my Windows licences? Thank you very much.
I had to send back my recently purchased laptop, the new one is looking forward to Audirvana but I forgot to uninstall prior to return. My main pc is already loaded with one instance of the program so I anticipate a too many installations notice - can you reset my PC registrations?
