Hi Damien - Just trying to get Audirvana on second Mac but getting âToo many installationsâ. I may have forgotten to clear a license on old computer.
Appreciate your assistance.
Thanks,
Marco
Thanks,
Marco
Hello @macboy6, I removed your computers in our database. You can now activate Audirvana up on two Mac.
Thanks, it worked.
Also wanted to say thanks for this amazing software Damien. It pairs with the Chordo Mojo amazingly, sounds brilliant and love the UI.
Marco
I forgot to revoke my installation when I recently had to reinstall Windows 10 twice. Can anyone help with my âtoo many install for you licenseâ issue? Thanks
Hello @faithhw,
Thank you for your message and for using AudirvÄna.
Your license allows you to activate AudirvÄna on 2 computers only.
You get the error message âtoo many installsâ if two installs are already registered and you try to activate AudirvÄna a new computer.
You can simply reset the computer installs associated with your license following instructions at Login To My Account - Easy Remove Audirvana 3.5 Activation. All you need is your license key and make sure you enter the email you have used to purchase your license initially.
We remind you that a major evolution of our software is now available in two versions - AudirvÄna Origin for local library only and AudirvÄna Studio with online streaming services also. Donât hesitate to try them at Try AudirvÄna - Download Now And Start A 30 Day Free Trial .
I hope this helps and donât hesitate to come back to us if you still have an issue.
