Hi I have a strange behaviour here: After a minute or so playing audio to my Topping E50 Audio-DAC it switches off (goes into suspend). According to the world wide web this happens if the DAC does not receieve a valid signal. Which is strange for many reasons, two of them are:
This happens while music is playing
This behaviour is new, it used to work flawlessly since I use this setup.
My System: Old Macbook Pro (from 2012 or so), Audirvana Studio latest version, Topping E50 DAC
This happens when I playback from harddisk (external SSD) and streaming from Tidal. It the same wheter I start directly from the macbook or start remotely with iphone or ipad. Iām on the studio subscription.
Hi @Audiopilot could you confirm how you DAC is connected to your Mac and also run your debug info from your Settings/Account page and paste the information in your reply in this thread. Hopefully someone can ascertain from that information what the problem could be.
I would also turn everything off in order of speakers/dac/Mac/router and remove plugs from power sockets for more than a minute, then restart in same order just to see if that irons out any kinks in the setup of the system.
Good luckā¦
If you can play your Local Library files using the built-in speakers as expected⦠then you have a point of reference from which to trouble-shoot your system⦠If you can playback from the built-in speakers, you will need to suspect the DAC or a bad USB cable or adapter⦠Verify the USB port the DAC is connected to if functioning by attaching something else to that portā¦
You can also verify the USB devices operating on the USB bus by opening āAbout This Macā and opening āSystem Reportā and look in the āHardwareā report for āUSBā and select to open the USB bus report to see the devices operating on the bus.
Here you are, but I donāt see something suspicious:
Audirvana Studio 2.9.2 (20902)
macOS 10.15.7 with 16GB physical RAM
Connected account of : xxxxxxxxx
Sync list: 2 folders
AUTO: /Users/musik/Library/Mobile Documents/com~apple~CloudDocs
AUTO: /Volumes/Extreme SSD/Musik
Library database path: /Users/musik/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 5244
Listening on 127.0.0.1 on port 49165
TIDAL: Connected as PREMIUM
Font size: regular
Language: Systemsprache
Meine Musik
Radios
Podcasts
Streaming
Lokal
Startup view: Meine Musik: Alben
Use Apple Remote: yes
Number of paired remotes: 3
Screen saver disabled: no
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Topping E50
Model UID:xxxxxxxxxxxxxxxxxxxxx
UID:AppleUSBAudioEngine:Topping:E50:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Selected device:E50
Manufacturer: Topping
Model name: Topping E50
Model UID: E50:152A:8750
UID: AppleUSBAudioEngine:Topping:E50:14100000:1
USB Vendor ID: 0x152a
USB Product ID: 0x8750
ID 0x38
MQA Decoder device
Stream ID 0x39 2 channels starting at 1
30 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 768kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
40 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 768kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 705.6kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
Device #0: ID 0x30 Ausgang (integriert)
Model UID: AppleHDA:82
Model name: Apple Inc. Ausgang (integriert)
Device #1: ID 0x38 E50
This is suspicious:
You are allocating 13.3GB of your 16GB System RAM for the playback pre-load memory buffer⦠I suggest lowering this allocation to @ 4GB.
You are leaving approximately 3GB of System RAM for macOS⦠You donāt need more than 4Gb for playback pre-load buffer⦠Increasing the available RAM for the OS, reduces virtual memory disc-swap request interrupts and the OS operates more efficientlyā¦
This is your interpretation of what āother tasks performed by your computer outside of the applicationā applies toā¦
You forget about bus management, system buffering, etc, etc⦠Audirvana does not run without CPU cycles and bus management sub-routines, etc, etc, like Core Audio functions and transmission protocol CODECs and the control of the flow of the memory bus architecture(s). ⦠You are making a presumption regarding the default allocation of System RAMā¦
