Hello, there is no native dsd option to choose on settings, only dop although dac has it.
Also upsampling to dsd512 (or any) doesnt work. When I play dsd64 track it tries for a moment to upsamle but then n immediately shows again dsd64.
Please help!
Ivan
Hi @vivan,
Note: When you click on the Debug Info button, Audirvana automatically copies all its content. Please paste it in response to this message
Audirvana Studio 2.8.1 (20801)
Windows 11 (22631) with 8GB physical RAM
Connected account of : Ivan Vihar
Available network interfaces:
Speedport-037469 ({e51c225a-aaf3-4a67-9b96-332dbc2534f8}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Bandwidth at 0dB = 91.1%
Filter max length = 3985
Anti-aliasing = 90.884
Phase = 66%
AUTO: C:\Users\Korisnik\Downloads
Library database path: C:\Users\Korisnik\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 2899
Listening on 192.168.1.120 on port 63096
TIDAL: Connected as PREMIUM
Font size: large
Show album covers in tracks list: no
My Music
Streaming
Radios
Podcasts
Startup view: Last displayed view
Use media keys: no
Number of paired remotes: 1
Screen saver disabled: yes
Local Audio Engine: ASIO 2
Driver version 1342
Speakers (TOPPING USB DAC)
Model UID:TUSBAUDIO_ENUM\VID_152A&PID_8750&REV_0104&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{3a51349b-ac2a-4eeb-afd2-7458a52d4068}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 8bits Integer, 2 bytes per frame 2822.4kHz
Active Sample Rate: 2822.4kHz
Selected device:Topping USB Audio Device
Manufacturer:
Model name: Topping USB Audio Device
Model UID: Topping USB Audio Device
2822400
5644800
11289600
22579200
Max volume alert: Disabled
Raw DSD (msb)
Device #0: Topping USB Audio Device
Manufacturer:
Chromecast devices found : 1
Device #0: Dnevna soba
Model name: Chromecast
Hi @vivan,
Can you please send a screenshot of Audirvāna Studio audio settings when you have this issue?
