Hello, i am using audirvana for win10, i am very pleased by its functionality and for supporting iso sacd- i have a big collection.
I am one step from purchasing a license, but i have a big problem, i get a 1 second dropout at about 13sec of playing a track, even worse, tracks are mixed after 30 minutes of playback. I increased my ram memory from 4gb to 12gb,with no result, problem remains. Is this a problem from my system or from the software? Thanks
Hello @Paladoiu_George, Can you send me a copy of the “Debug Info”? You can get it in Audirvana Settings>General>Debug Info
Audirvana 3.5.9
Manual: D:\SACD ISO
Library database path: C:\Users\pgeob\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: TEAC NT-505:TEAC Model UID:TEAC Corporation TEAC NT-505:TEAC UID:uuid:4c494e4e-3d9b-11e1-b86c-0016e8452218
UPnP device at http://192.168.0.11:23000/
TEAC NT-505:TEAC Manufacturer:TEAC Corporation
Volume control: No
DSD capability: Raw DSD (MSB)
http-get:::*
http-get::audio/mpeg:
http-get::audio/mpeg3:
http-get::audio/mp3:
http-get::audio/x-mp3:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp4:
http-get::audio/mpeg4-generic:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aac:
http-get::audio/alac:
http-get::audio/x-alac:
http-get::audio/dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/octet-stream:
DLNA 1.5: Yes
Gapless playback: Yes
Can play native DSD: Yes
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID CurrentPlayMode string NORMAL NORMAL REPEAT_ONE REPEAT_ALL SHUFFLE SHUFFLE_NOREPEAT RecordStorageMedium string NOT_IMPLEMENTED LastChange string RelativeTimePosition string CurrentTrackURI string CurrentTrackDuration string CurrentRecordQualityMode string NOT_IMPLEMENTED CurrentMediaDuration string AbsoluteCounterPosition i4 RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 AVTransportURI string TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT CurrentTrackMetaData string NextAVTransportURI string PossibleRecordQualityModes string NOT_IMPLEMENTED CurrentTrack ui4 0 65535 1 AbsoluteTimePosition string NextAVTransportURIMetaData string PlaybackStorageMedium string NONE UNKNOWN CD-DA HDD NETWORK CurrentTransportActions string RecordMediumWriteStatus string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NONE UNKNOWN CD-DA HDD NETWORK AVTransportURIMetaData string NumberOfTracks ui4 0 65535 A_ARG_TYPE_SeekMode string REL_TIME TRACK_NR A_ARG_TYPE_SeekTarget string PossibleRecordStorageMedia string NOT_IMPLEMENTED TransportStatus string OK ERROR_OCCURRED TransportPlaySpeed string 1Current device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 TEAC NT-505:TEAC TEAC Corporation http://audio.teac.com/ TEAC TEAC 1.0 http://audio.teac.com/ uuid:4c494e4e-3d9b-11e1-b86c-0016e8452218 DMR-1.50 image/png 120 120 24 /images/lumin-120x120.png image/png 48 48 24 /images/lumin-48x48.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /Product/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /Product/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /Product/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /Playlist/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /Playlist/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /Playlist/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /Time/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /Time/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /Time/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /Info/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /Info/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /Info/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /Volume/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /Volume/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /Volume/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:av-openhome-org:service:Transport:1 urn:av-openhome-org:serviceId:Transport /Transport/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /Transport/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /Transport/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:magictv-com:service:MagicAudio:1 urn:magictv-com:serviceId:MagicAudio /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /Credentials/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /Credentials/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /Credentials/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xml urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /Radio/4c494e4e-3d9b-11e1-b86c-0016e8452218/scpd.xml /Radio/4c494e4e-3d9b-11e1-b86c-0016e8452218/control.xml /Radio/4c494e4e-3d9b-11e1-b86c-0016e8452218/event.xmlUPnP devices found : 1
Device #0TEAC NT-505:TEAC UID: uuid:4c494e4e-3d9b-11e1-b86c-0016e8452218 Location: http://192.168.0.11:23000/
Max. memory for audio buffers: 256MB
Local Audio Engine:WASAPI
Device #0: Line 1/2 (M-Audio Delta AP 192) Manufacturer: Model UID: Line 1/2 (M-Audio Delta AP 192) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3d91eb3a-0483-4731-8b02-e9d063a471f0}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: S/PDIF (M-Audio Delta AP 192) Manufacturer: Model UID: S/PDIF (M-Audio Delta AP 192) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{71bf52ca-7b70-42fd-b9f4-103b366c052c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Have you tried to connect via USB just as a test?
Also try to reduce the preload memory allocation to bare minimum, for example 1024MB.
I did not try usb, i have pc too far from amplifier-speakers and dac, but i tried roon and works fine without problems.
I have buffer set at minimum 256mb.
I just tried usb and works great, with no problem.
Then it’s one of those UPnP issues. It will be hard to correct, but while you wait on Audirvana, you might want to ask Teak to also have a look into this. Maybe they’re coming with a new firmware release in the near future.
Thanks for your answers
