I stream using Qobuz. When i start playing a whole playlist or an album and I want to move on to the next track, using the “next” icon on the player . This results in complete stoppage of music playback. Next track won’t load/play. This happens also when going to the queue and manually selecting tracks , plays the first track, then if you play the 5th or second track , nothing happens. Playback stops. Please help. Thanks. Happens both in Mac and Windows . My streamer is Cambridge cxn v2
Does this happen also with local files?
Yes. It happens even in local files also. You press the next button to play the next song and Audirvana just stops working. Also, the issue of tracks not finishing to play until the end is back. This issue was fixed by uninstalling and reinstalling but now it’s back
It looks like UPnP issue. Try using USB.
Dump your debug info here.
Audirvana 3.5.41
AUTO: D:\MyFlac
Library database path: C:\Users\iapa\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Mossaic Model UID:Cambridge Audio Mossaic UID:uuid:b5f68c6e-1e91-4877-b946-e560456ec0b9
UPnP device at http://10.0.0.29:8050/b5f68c6e-1e91-4877-b946-e560456ec0b9/description.xml
Mossaic Manufacturer:Cambridge Audio
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/mpeg:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
NrTracks: 2
MediaDuration: 0:03:45
CurrentURI: http://10.0.0.31:49152/audirvana/audio_0_75.wav
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI: http://10.0.0.31:49152/audirvana/audio_1_76.wav
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Mossaic Cambridge Audio http://www.cambridgeaudio.com/ CXNv2 3476 uuid:b5f68c6e-1e91-4877-b946-e560456ec0b9 00203246 image/png 48 48 8 /b5f68c6e-1e91-4877-b946-e560456ec0b9/CA-roundal-48x48.png image/jpeg 48 48 24 /b5f68c6e-1e91-4877-b946-e560456ec0b9/CA-roundal-48x48.jpg image/png 120 120 8 /b5f68c6e-1e91-4877-b946-e560456ec0b9/CA-roundal-120x120.png image/jpeg 120 120 24 /b5f68c6e-1e91-4877-b946-e560456ec0b9/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /b5f68c6e-1e91-4877-b946-e560456ec0b9/RenderingControl/RenderingControl1.xml /b5f68c6e-1e91-4877-b946-e560456ec0b9/RenderingControl/invoke /b5f68c6e-1e91-4877-b946-e560456ec0b9/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /b5f68c6e-1e91-4877-b946-e560456ec0b9/ConnectionManager/ConnectionManager1.xml /b5f68c6e-1e91-4877-b946-e560456ec0b9/ConnectionManager/invoke /b5f68c6e-1e91-4877-b946-e560456ec0b9/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /b5f68c6e-1e91-4877-b946-e560456ec0b9/ContentDirectory/ContentDirectory1.xml /b5f68c6e-1e91-4877-b946-e560456ec0b9/ContentDirectory/invoke /b5f68c6e-1e91-4877-b946-e560456ec0b9/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /b5f68c6e-1e91-4877-b946-e560456ec0b9/AVTransport/AVTransport1.xml /b5f68c6e-1e91-4877-b946-e560456ec0b9/AVTransport/invoke /b5f68c6e-1e91-4877-b946-e560456ec0b9/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /b5f68c6e-1e91-4877-b946-e560456ec0b9/RecivaRadio/RecivaRadio.xml /b5f68c6e-1e91-4877-b946-e560456ec0b9/RecivaRadio/invoke /b5f68c6e-1e91-4877-b946-e560456ec0b9/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /b5f68c6e-1e91-4877-b946-e560456ec0b9/UuPlaylist/Playlist.xml /b5f68c6e-1e91-4877-b946-e560456ec0b9/UuPlaylist/invoke /b5f68c6e-1e91-4877-b946-e560456ec0b9/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /b5f68c6e-1e91-4877-b946-e560456ec0b9/RecivaSimpleRemote/RecivaSimpleRemote.xml /b5f68c6e-1e91-4877-b946-e560456ec0b9/RecivaSimpleRemote/invoke /b5f68c6e-1e91-4877-b946-e560456ec0b9/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /b5f68c6e-1e91-4877-b946-e560456ec0b9/StreamMagic6/StreamMagic6.xml /b5f68c6e-1e91-4877-b946-e560456ec0b9/StreamMagic6/invoke /b5f68c6e-1e91-4877-b946-e560456ec0b9/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /b5f68c6e-1e91-4877-b946-e560456ec0b9/SMSearch/SMSearch.xml /b5f68c6e-1e91-4877-b946-e560456ec0b9/SMSearch/invoke /b5f68c6e-1e91-4877-b946-e560456ec0b9/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 6
Device #0Mossaic UID: uuid:b5f68c6e-1e91-4877-b946-e560456ec0b9 Location: http://10.0.0.29:8050/b5f68c6e-1e91-4877-b946-e560456ec0b9/description.xml
Device #1Denon AVR-X4500H UID: uuid:26282034-487e-127f-0080-0005cdfe2f9a Location: http://10.0.0.3:60006/upnp/desc/aios_device/aios_device.xml
Device #2Denon AVR-X4500H UID: uuid:eff8cad5-c406-1da7-0080-0005cdfe2f9a Location: http://10.0.0.3:60006/upnp/desc/aios_device/aios_device.xml
Device #3Denon AVR-X4500H UID: uuid:342ebc37-5db0-19af-0080-0005cdfe2f9a Location: http://10.0.0.3:60006/upnp/desc/aios_device/aios_device.xml
Device #4Denon AVR-X4500H UID: uuid:bd492ff9-6799-3419-bd5b-a16083fad98d Location: http://10.0.0.3:60006/upnp/desc/aios_device/aios_device.xml
Device #5Denon AVR-X4500H UID: uuid:da90fb62-9f78-94d0-6071-c959c04a35a8 Location: http://10.0.0.3:60006/upnp/desc/aios_device/aios_device.xml
Max. memory for audio buffers: 11038MB
Local Audio Engine:WASAPI
Device #0: Speakers (Realtek® Audio) Manufacturer: Model UID: Speakers (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{c0be2ad3-1585-4ea1-ae94-9d47a5b422bf}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
