Hi everyone.
Audirvana Studio says: Trial is active to 31 Juli 2022, is that normal?
My account says: Audirvana Studio Access to 31 Juli 2022.
The reason for my concern is that there are at least 1 feature that is limited in trial mode.
Please Help.
just log out in the application preferences… and log back in
@RunHomeSlow is correct. Many people, including myself, had this issue. It seems to be a common bug.
Just go to Settings → My Account → Click here to disconnect. Then after you restart AS log back in
Thanks a lot, both of you, did as you said & it worked like a charm, Thanks!
