Hi, I have been trialling Audirvana for a about 3 days. Looking to replace my Roon subscription.
Right as I was considering flashing my RPi to see if I can get Audirvana into multiple rooms, I am no longer able to open Audirvana.
While I believe the lifetime purchase is quite affordable, I am not ready to pull the trigger and unsure why it won’t let me open the app only 3 days into the 30 day trial.
Can you check if you have logs of Audirvana for this particular issue? It can be in two different locations :
C:\Users\[your login]\AppData\Local\Packages\Audirvana.Audirvana-[… id number that can vary]\LocalCache\Local\Audirvana\Audirvana
C:\Users\[your login]\AppData\Local\Audirvana\Audirvana
If you have logs in one of these location can you send me the file in private message?
