Voici le début info:
macOS 10.12.6 with 8192MB RAM
Licence enregistrée pour TERRACOL Yves
SW volume control: ON
Sync list: 5 folders
AUTO: /Users/Musique/Music/Comparaison
AUTO: /Users/Musique/Music/Discothèque CD
AUTO: /Users/Musique/Music/Fichiers DSD
AUTO: /Users/Musique/Music/Qobuz
AUTO: /Users/Musique/Music/iTunes/iTunes Media/Music
Library database path: /Users/Musique/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
CoreAudio audio path, buffer I/O frame size: 4096
Max. memory for audio buffers: 4220MB
Mytek_FireWire
Model UID:MytekDiceDrv:DICE Device
UID:MytekDiceDrvAudioEngine:0
Device: 4ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 16 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
ID 0x40 Mytek_FireWire Manufacturer:Mytek
Model UID:MytekDiceDrv:DICE Device UID:MytekDiceDrvAudioEngine:0
Multichannel: 4 channels
Channel 2 mapped to 2
Channel 3 mapped to 3
Number of channels: 4
Simple stereo device: No
Number of active channels: 4, in 1 stream(s)
Stream ID 0x41 4 channels starting at 1
6 virtual formats:
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
6 physical formats
4 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 192kHz
4 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 176.4kHz
4 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz
4 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz
4 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz
4 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz
Device #0: ID 0x2e Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:39 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x40 Mytek_FireWire Manufacturer: Mytek Model UID: MytekDiceDrv:DICE Device UID: MytekDiceDrvAudioEngine:0
UPnP devices found : 1
Device #0: ID 0x0 La box Fibre UID: uuid:56066f6e-6b79-4d65-648c-4065a38cb19c Location: http://192.168.0.14:9001/6/TMRDeviceDescription.xml
