DSD64 files play one song and then PC freezes. DSD128, 256 and 512 do not play at all. PC gives a mini dump message. How do I rectify this?
Can you dump the debug info here?
Hello @jeffwells,
Sun, Dec 13, 3:51 PM (2 days ago)
to Alex
ccccccccccccccccccccccccAudirvana 3.5.42
Sync list: 2 folders
AUTO: C:\Users\jeff\Music\Acoustic Sounds Super HiRez
AUTO: C:\Users\jeff\Music\iTunes\iTunes Media\Music
Library database path: C:\Users\jeff\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3818MB
Local Audio Engine:ASIO 2 driver version 2
Combo384 ASIO 1.03
Model UID:Combo384 ASIO 1.03
Device: 16ch 32bits Integer, 64 bytes per frame 44.1kHz
Combo384 ASIO 1.03 Manufacturer:
Model UID:Combo384 ASIO 1.03 UID:Combo384 ASIO 1.03
17 available sample rates up to 45158400Hz
1411200
1536000
2822400
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
Multichannel: 16 channels
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Channel 8 mapped to 8
Channel 9 mapped to 9
Channel 10 mapped to 10
Channel 11 mapped to 11
Channel 12 mapped to 12
Channel 13 mapped to 13
Channel 14 mapped to 14
Channel 15 mapped to 15
Number of channels: 16
Simple stereo device: No
Number of active channels: 16, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Channel #8 :Stream 0 channel 8
Channel #9 :Stream 0 channel 9
Channel #10 :Stream 0 channel 10
Channel #11 :Stream 0 channel 11
Channel #12 :Stream 0 channel 12
Channel #13 :Stream 0 channel 13
Channel #14 :Stream 0 channel 14
Channel #15 :Stream 0 channel 15
16 ch Integer PCM 32bit little endian 44.1kHz
16 ch Integer PCM 32bit little endian 48kHz
16 ch Integer PCM 32bit little endian 88.2kHz
16 ch Integer PCM 32bit little endian 96kHz
16 ch Integer PCM 32bit little endian 176.4kHz
16 ch Integer PCM 32bit little endian 192kHz
16 ch Integer PCM 32bit little endian 352.8kHz
16 ch Integer PCM 32bit little endian 384kHz
16 ch Integer PCM 32bit little endian 705.6kHz
16 ch Integer PCM 32bit little endian 768kHz
16 ch Integer PCM 32bit little endian 1411.2kHz
16 ch Integer PCM 32bit little endian 1536kHz
16 ch DSD 8bit big endian in 8bit chunk 2822.4kHz
16 ch DSD 8bit big endian in 8bit chunk 5644.8kHz
16 ch DSD 8bit big endian in 8bit chunk 11289.6kHz
16 ch DSD 8bit big endian in 8bit chunk 22579.2kHz
16 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: Combo384 ASIO 1.03 Manufacturer: Model UID: Combo384 ASIO 1.03 UID: Combo384 ASIO 1.03
Is this what you wanted?
Jeff
Try to switch the DSD setting to DSD over PCM (DoP) 1.0. Which DAC do you have?
Wells Audio Cipher DAC.
Thank you for the debug info, can you also send us the dump file created at [email protected]?
