macOS 10.14.6 with 16384MB RAM
Registered to ***** ******
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Wed Sep 29 20:56:23 2021
Library database path: /Users/cleyden/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4096MB
FiiO USB DAC-E10
Model UID:FiiO USB DAC-E10:1852:7022
UID:AppleUSBAudioEngine:FiiO:DigiHug USB Audio:2300000:3
Active Sample Rate: 48kHz
ID 0x2a FiiO USB DAC-E10 Manufacturer:FiiO
Model UID:FiiO USB DAC-E10:1852:7022 UID:AppleUSBAudioEngine:FiiO:DigiHug USB Audio:300000:3
32000
Stream ID 0x2b 2 channels starting at 1
12 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
16 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
Local devices found : 4
Device #0: ID 0x50 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:29 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x3a CalDigit Thunderbolt 3 Audio Manufacturer: CalDigit, Inc. Model UID: CalDigit Thunderbolt 3 Audio:2188:6533 UID: AppleUSBAudioEngine:CalDigit, Inc.:CalDigit Thunderbolt 3 Audio:2200000:1
Device #2: ID 0x2a FiiO USB DAC-E10 Manufacturer: FiiO Model UID: FiiO USB DAC-E10:1852:7022 UID: AppleUSBAudioEngine:FiiO:DigiHug USB Audio:300000:3
Device #3: ID 0x40 Reincubate Manufacturer: Reincubate Model UID: CamoAudioDevice_ModelUID UID: CamoAudioDevice_UID
