Fabulous idea… But, every time I try to load a folder to the library I get this message
Can anyone explain why.
Thanks Phil
Thanks Phil
Hello @philipjohnson,
Are you able to access to this folder using Finder and play tracks you have in it by drag and dropping some of them in the play queue?
Thanks Antoine. I fixed (?) by relocating the database file and all folders appear in AO. Odly many of the files appear as they were configures six months ago.
All is well and I’m really pleased with this new version with only local files.
Thank you.
