Damien – no, I only have .AIFF and .ALAC in my library.
This is the debug report from this morning, while the bug is ‘active’. This happens every morning, and sometimes later in the day, when I haven’t used Adv for a few hours. I’ll need to completely restart my system now to get any output from Adv.
I really hope we can fix this… I don’t want to go back to using JRiver!
macOS 10.13.6 with 16384MB RAM
AUTO: /Users/timdanaher/Music/iTunes/iTunes Media/Music
iTunes/Music library synchronization: last synchronized on Sat Jan 16 18:49:03 2021
Library database path: /Users/timdanaher/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
D30
Model UID:D30:20B1:3066
UID:AppleUSBAudioEngine:Topping:D30:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
ID 0x28 D30 Manufacturer:Topping
Model UID:D30:20B1:3066 UID:AppleUSBAudioEngine:Topping:D30:14100000:1
Stream ID 0x29 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 3
Device #0: ID 0x46 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x28 D30 Manufacturer: Topping Model UID: D30:20B1:3066 UID: AppleUSBAudioEngine:Topping:D30:14100000:1
Device #2: ID 0x31 LogMeIn Remote Sound Manufacturer: LogMeIn Inc. Model UID: com_logmein_driver_LogMeInSoundDevice:DeviceName UID: LogMeInSoundEngine:0
