The situation with Mac Studio is quite different to Windows. With the u BACCH plug-in and Realtime, most of the time there is no sound, no matter how long await. Sometimes eventually the sound comes; but, as previously reported, is broken up.
On Windows there is silence for one to two minutes (could be more) depending on the length of the track. Then the first track requested does start playing; but from that one to two minute point, not form the beginning. So a large part of the beginning of the track is cut-off with silence.
I’m attaching debug info…
Debug info Mac Studio - Realtime off No sound
Audirvana Studio 2.6.1 (20601)
macOS 13.2.1 with 32GB physical RAM
Connected account of : Geoffrey Armstrong
Effects plugins ACTIVE in offline mode with legacy macOS API
AU plugin #0: Effect - BACCH Labs uBACCHaudio ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
AUTO: /Volumes/WESTDIG2/
Library database path: /Users/geoffreyarmstrong/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 24085
Listening on 127.0.0.1 on port 55122
TIDAL: Connected as HiFi Plus
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Actual I/O buffer frame size: 4096
exaSound Audio Design exaSound
Model UID:exaSound-N1
UID:exaSoundDevice-N1
Hog Mode is on
Selected device:exaSound
Manufacturer: exaSound Audio Design
Model name: exaSound Audio Design exaSound
Model UID: exaSound-N1
UID: exaSoundDevice-N1
ID 0x4e
Max volume alert: Disabled
Stream ID 0x4f 2 channels starting at 1
20 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 768kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 705.6kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 384kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 352.8kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
20 physical formats
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 768kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 705.6kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz
Local devices found : 4
Device #0: ID 0x37 USB PnP Audio Device
Manufacturer: Unknown Manufacturer
Model UID: USB PnP Audio Device:0C76:153F
UID: AppleUSBAudioEngine:Unknown Manufacturer:USB PnP Audio Device:3124000:1
USB Vendor ID: 0x0c76
USB Product ID: 0x153f
Model name: Unknown Manufacturer USB PnP Audio Device
Device #1: ID 0x3d BlackHole 16ch
Manufacturer: Existential Audio Inc.
Model UID: BlackHole16ch_ModelUID
UID: BlackHole16ch_UID
Model name: Existential Audio Inc. BlackHole 16ch
Device #2: ID 0x6e Mac Studio Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Mac Studio Speakers
Device #3: ID 0x4e exaSound
Debug info Mac Studio - Realtime on Sound
Effects plugins ACTIVE in realtime mode with legacy macOS API
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Integer mode: ON
Hog Mode is on
ID 0x4e
20 virtual formats:
20 physical formats
Model UID: Speaker
