This is with the latest iOS and Windows 11 developer builds:
I did a search for Radio Paradise, which brings up several radio stations. I tapped View All to select the particular station I wanted, and the thumbnails for the choices were displayed. However, when I touched the screen to begin scrolling through the choices, the list immediately dropped down several selections (past the one I wanted), and it wouldn’t move from that position when I tried to swipe up and down.
I repeated this several times and the same thing happened each time.
Can you do a screen record of it and send it to support@audirvana.com? this will help me reproduce the issue and see if it occurs on other iOS devices.
The prior bug may not have been the fault of Audirvana Remote. I use the iOS developer betas, but the latest iOS version is the 17.3 release, not the developer beta installed on the phone when I had the bug. So I think you can safely consider this one resolved by updating iOS to the 17.3 release version.
