Hi @ antoine. Debug Info as requested below.
Audirvana Studio 3.3.1 (30301)
Running on MacBook Pro (16-inch, M5 Max), Apple M5 Max
macOS 26.5.1 ARM64 with 48GB physical RAM
Connected account of : David Moore
Local network access: allowed
REMOTE CONTROL SERVER:
Listening on
en0 IPv6: fd01:8280:ff5a:4d8a:c0c:f4:adf7:e3c1
en0 IPv4: 192.168.50.162
on port 49693
LOADING/DECODING:
Max audio buffer size: 8172MB
Convolver: OFF
Internal EQ: OFF
Crossfeed: OFF
Balance: OFF
PLUGINS: NOT ACTIVE
Volume step size: 1dB
AUTO: /Users/David/Music/Audio Library
Sync folders at startup: YES
Sort and display order: en
Library database path: /Users/David/Music/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 693
Font size: regular
Favorites
Playlists
Streaming
Radios
Podcasts
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: yes
Active method: UPnP
Wi-Fi
Preferred device: [UPnP] Devialet Phantom Ultimate Duo Model UID:Devialet Phantom Ultimate 98 dB UID:uuid:77450871-29b0-4af5-82d3-5427a7363b75
Currently playing to UPnP device at 24 bits 88.2kHz
Selected device: Devialet Phantom Ultimate Duo
Manufacturer: Devialet
Model name: Phantom Ultimate 98 dB
Model UID: Devialet Phantom Ultimate 98 dB
UID: uuid:77450871-29b0-4af5-82d3-5427a7363b75
Plays with Audirvāna: Yes
Override manufacturer settings: Yes
UPnP device at http://192.168.50.235:16500/77450871-29b0-4af5-82d3-5427a7363b75.xml
ID 0x0
Volume control: Yes
Channel 0: L
Channel 1: R
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
Universal gapless playback active: No
Unwanted playback stop workaround: Yes
UPnP capabilities
DLNA 1.5: Yes
Service versions:
AVTransport: v1
RenderingControl: v1
ConnectionManager: v1
Native gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume control: scalar
Output configuration
Output streams: 1
Active channels: 2, in 1 stream(s)
Channel #0: Stream 0 channel 0
Channel #1: Stream 0 channel 1
12 virtual formats:
0 physical formats
Current device state
Transport info:
Media info:
NrTracks: 1
MediaDuration: 0:07:55
CurrentURI: http://192.168.50.162:49152/audirvana/audio_f_0.wav
CurrentURIMetadata:
dc:titleTransatlanticism</dc:title>
dc:creatorDeath Cab For Cutie</dc:creator>
upnp:artistDeath Cab For Cutie</upnp:artist>
<upnp:author role=“Composer”>Benjamin Gibbard</upnp:author>
upnp:genreAlternative & Indie</upnp:genre>
upnp:albumArtURIhttp://192.168.50.162:49152/audirvana/artwork_0_0.jpg</upnp:albumArtURI>
upnp:albumTransatlanticism</upnp:album>
upnp:originalTrackNumber7</upnp:originalTrackNumber>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Transport actions: Pause,Stop,Previous,Seek
http-get::audio/wave:
http-get::audio/ogg:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::audio/vorbis:
http-get::audio/wav:
http-get::audio/m4a:
http-get::audio/flac:
http-get::audio/x-aac:
http-get::audio/x-aiff:
http-get::audio/aac:
http-get::application/ogg:
http-get::text/xml:
http-get::audio/mpeg:
http-get::audio/x-flac:
http-get::audio/aiff:
http-get::audio/mpegurl:
http-get::audio/x-mpegurl:
http-get::video/mpegurl:
http-get::video/x-mpegurl:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-aac:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/mpegurl:
rtsp-rtp-udp::audio/x-mpegurl:
rtsp-rtp-udp::video/mpegurl:
rtsp-rtp-udp::video/x-mpegurl:
Device description (live, downloaded from device)
<?xml version="1.0"?>
1
0
QPlay:2.1
Devialet
http://www.devialet.com/
U23A30371LP51
image/png
120
120
24
/LibRygelRenderer-120x120x24.png
image/png
48
48
24
/LibRygelRenderer-48x48x24.png
image/jpeg
120
120
24
/LibRygelRenderer-120x120x24.jpg
image/jpeg
48
48
24
/LibRygelRenderer-48x48x24.jpg
/xml/ConnectionManager.xml
/Control/LibRygelRenderer/RygelSinkConnectionManager
/Event/LibRygelRenderer/RygelSinkConnectionManager
/xml/AVTransport2.xml
/Control/LibRygelRenderer/RygelAVTransport
/Event/LibRygelRenderer/RygelAVTransport
/xml/RenderingControl2.xml
/Control/LibRygelRenderer/RygelRenderingControl
/Event/LibRygelRenderer/RygelRenderingControl
urn:schemas-tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/xml/QPlayDescription.xml
/Control/LibRygelRenderer/QPlay
/Event/LibRygelRenderer/QPlay
http://192.168.50.235:80/
DMR-1.51
Device description (cached from discovery)
1
0
QPlay:2.1
Devialet
U23A30371LP51
image/png
120
120
24
image/png
48
48
24
image/jpeg
120
120
24
image/jpeg
48
48
24
DMR-1.51
UPnP devices found : 4
Device #0: ID 0x0 : Devialet Phantom Ultimate Duo
Location: http://192.168.50.235:16500/77450871-29b0-4af5-82d3-5427a7363b75.xml
Device #1: ID 0x0 : Naim Uniti Atom HE
UID: uuid:a0b8ec64-b323-423d-a876-0b73a3d3fe12
Location: http://192.168.50.81:43086/a0b8ec64-b323-423d-a876-0b73a3d3fe12.xml
Manufacturer: Naim Audio
Model name: Uniti Atom HE
Device #2: ID 0x0 : LS50 Wireless II
UID: uuid:8cfe32cf-ad5c-4738-b6d7-6fa05f64e756
Location: http://192.168.50.7:16500/8cfe32cf-ad5c-4738-b6d7-6fa05f64e756.xml
Manufacturer: KEF
Model name: LS50 Wireless II
Device #3: ID 0x0 : Chord 2Go:Hugo2
UID: uuid:a9b833c0-66ec-ed70-8036-00602f070564
Location: http://192.168.50.48:49152/uuid-a9b833c0-66ec-ed70-8036-00602f070564/description.xml
Manufacturer: Chord Electronics
Model name: 2Go
Max. memory for audio buffers: 8172MB
CoreAudio
Device #0: ID 0x47 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Chromecast devices found : 2
Device #0: Devialet Phantom Ultimate Duo
Device #1: LS50 Wireless II
