Trial user here - really enjoying the software and am tempted to purchase the dual-OS license when it releases next week, though I’m currently running into a mildly annoying issue.
I use a high-refresh rate monitor on my PC, and I’m noticing that Audirvana seems to stutter quite a bit. Almost like whenever the application is selected or focused, it’s lowering the refresh rate of the system back down to 60hz rather than operating at the default refresh rate (120hz in my case). It only happens when the app is selected - if it’s open in the background it works fine.
Not sure if there’s a way to fix this? I’ve checked all my GPU and display settings to no avail. Really like the software but this is a somewhat annoying little bug.
Thanks in advance.
