Hi Damien,
Just register my audirvana download on window 10,
It show unable to change to integer mode and device not conneted.
Thank you
Hi Damien,
Thank you
Hello @shin,
Hi Damien,
Sorry for the late reply.
Please refer the attach debug log
Thank you.
Audirvana 3.5.44
AUTO: D:\QQ Music
Library database path: C:\Users\yw_sh\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 6128MB
Local Audio Engine:WASAPI
Speakers (Realtek® Audio)
Model UID:Speakers (Realtek® Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{67755ef6-5b62-4a91-aae7-6a21a00c7f7d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Speakers (Realtek® Audio) Manufacturer:
Model UID:Speakers (Realtek® Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{67755ef6-5b62-4a91-aae7-6a21a00c7f7d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
0 available sample rates up to 0Hz
Multichannel: 8 channels
Channel bitmap: Oxff, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Device #0: Speakers (Realtek® Audio) Manufacturer: Model UID: Speakers (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{67755ef6-5b62-4a91-aae7-6a21a00c7f7d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Can you try to select ASIO? do you have a driver that can be selected?
Hi Damien,
Select ASIO and still the same problem.
Thank you.
Audirvana 3.5.44
AUTO: D:\QQ Music
Max. memory for audio buffers: 5976MB
Local Audio Engine:ASIO 2 driver version 0
FiiO ASIO Driver Manufacturer:
Model UID:FiiO ASIO Driver UID:FiiO ASIO Driver
0 output streams:
Number of active channels: 2
Device #0: FiiO ASIO Driver Manufacturer: Model UID: FiiO ASIO Driver UID: FiiO ASIO Driver
Debug log
What is the device you have connected to your computer?
Hi Damien,
The Fiio is my mp3 player software but i just need audirvana just play music from my computer.
And i using Msi GE73 raider laptop.
How to change setting ASIO play from my computer?
Thank you.
Hi Damien,
After install the ASIO4ALL audirvana working already.
May i know where can download the wasapi cos ASIO working but Wasapi same problem.
Thank you.
You can try to reinstall your audio driver using this link:
Hi Damien,
Thank you.
