After installing the audio software “Nahimic”, the message “unable to change to integer mode” will appear if the DAC is selected to “Realtek Digital Output”. It will be resumed after that software is uninstalled. Has anyone encounter the same problem and can fix it?
As long as Nahimic is installed, the issue will happen.
