All of a sudden unable to reconnect to Qobuz account on the streaming tab.
You went to audirvana preferences?? account tab, disconnect from quobuz⌠restart computer maybe, then open audirvana, go again to account then reconnect to Quobuz
Yes. Also reconnected to Audirvana. Qobuz was acting strange, so I disconnected and now not able to reconnect. Login screen appears, enter login info, press signin and nothing.
Hi @carvalho1226,
Can you go into the AudirvÄna settings and in the My Account section? You will see a âStart Log Sessionâ button; click on it and reproduce your issue. After you reproduce it, click 'Stop Log Sessionâ and send me the audirvana_studio.log you can find by clicking the 'Open Log Folderâ button at [email protected].
I have no idea what happened, but I was able to launch AS on another machine, log into Qobuz, shut it down, and then successfully connect to Qobuz via AS on the machine that wouldnât connect earlier.
Is there an official solution to this issue? Iâm experiencing the exact same issue again, and the workaround doesnât seem like a very good permanent solution.
Hi @carvalho1226 , can you please do what I asked in my previous message and send me the corresponding file?
File has been emailed to support.
Thank youâŚ
