Hello everybody,
Since today I am unable to open or load anything…any help appreciated!
I am using without any problems Audirvana since about two years!
Here the debug infor and many thanks in advance!
Audirvana Studio 1.12.2 (11202)
Windows 11 (22000) with 8GB physical RAM
Connected account of : Francesco Doenz
Sync list: 0 folders
Library database path: C:\Users\franc\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.17 on port 53602
TIDAL: Connected as FREE
Preferred device: Lyngdorf TDAI-3400-7C71FF Model UID:Lyngdorf TDAI-3400-7C71FF UID:uuid:f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8
UPnP device at http://169.254.8.116:41895/f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8.xml
TDAI-3400-7C71FF
Manufacturer: Lyngdorf
Model Name:
Model UID: Lyngdorf TDAI-3400-7C71FF
UID: uuid:f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8
Volume control: No
Avoid RAW PCM streams: Yes
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/flac:
http-get::audio/m4a:
http-get::application/ogg:
http-get::audio/wav:
http-get::audio/x-m4a:
http-get::audio/x-wav:
http-get::audio/x-aac:
http-get::audio/mpeg:
http-get::audio/aiff:
http-get::audio/x-flac:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::text/xml:
http-get::audio/x-aiff:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-aac:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/x-aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 TDAI-3400-7C71FF Lyngdorf http://lyngdorf.com/ TDAI-3400 http://lyngdorf.com/ 0050C27C71FF uuid:f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://169.254.11.8/ DMR-1.51UPnP devices found : 1
Device #0TDAI-3400-7C71FF UID: uuid:f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8 Location: http://169.254.8.116:41895/f8f0c9a9-e4fb-46dd-8770-e4e4230f99a8.xml
Max. memory for audio buffers: 6058MB
Local devices found : 15
Device #0: DAX RESERVED AUDIO RX 5 (FlexRadio Systems DAX Audio) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_Audio UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3ef0eaef-c8d6-440c-8534-d03634b274be}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #1: DAX Audio TX (FlexRadio Systems DAX TX) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_TX UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{857111b6-0124-4677-93ba-bee51a9ff3d7}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #2: DAX RESERVED AUDIO RX 6 (FlexRadio Systems DAX Audio) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_Audio UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{300cf4df-b6ca-490c-b8b8-04a0eabf260b}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #3: DAX RESERVED IQ RX 4 (FlexRadio Systems DAX IQ) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_IQ UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7344594e-2fa9-4ba2-9f8d-11212ec3075c}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #4: DAX RESERVED MIC AUDIO (FlexRadio Systems DAX MIC Audio) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_MICAudio UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{883276eb-9508-40bb-848d-b26d29ba96f3}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #5: DAX RESERVED AUDIO RX 2 (FlexRadio Systems DAX Audio) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_Audio UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7e765889-ab73-4861-8068-043cd02d4460}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #6: DAX RESERVED AUDIO RX 3 (FlexRadio Systems DAX Audio) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_Audio UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{bacebbab-6876-41b0-be37-d630336f565c}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #7: DAX RESERVED AUDIO RX 1 (FlexRadio Systems DAX Audio) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_Audio UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{91224880-2c94-4ec3-af7b-ddb5fa1473b4}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #8: DAX RESERVED AUDIO RX 4 (FlexRadio Systems DAX Audio) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_Audio UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2b1d19f8-bf92-46b7-afa5-9cda5d32ff56}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #9: DAX RESERVED IQ RX 1 (FlexRadio Systems DAX IQ) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_IQ UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{6fbddf72-62ba-43fb-9870-08f15a868fc8}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #10: DAX RESERVED IQ RX 3 (FlexRadio Systems DAX IQ) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_IQ UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{97fc6185-ff4a-49b7-9ccf-4e0e3ade095e}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #11: DAX RESERVED IQ RX 2 (FlexRadio Systems DAX IQ) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_IQ UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4f0d6ef2-2217-41eb-afec-155da1da32f4}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #12: DAX RESERVED AUDIO RX 8 (FlexRadio Systems DAX Audio) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_Audio UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{bafd9744-042a-4153-83c7-3d21dc77b048}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #13: DAX RESERVED AUDIO RX 7 (FlexRadio Systems DAX Audio) Manufacturer: FlexRadio Systems Model UID: FlexRadioSystems_DAX_Audio UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b6789d8c-af2e-4262-ad9b-84211de0bff6}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #14: Speakers (Realtek High Definition Audio(SST)) Manufacturer: Realtek Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0255&SUBSYS_1025121E&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{65cd4e09-0de2-4627-b9d0-0c711158353d}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
