I’m at my wits end. I have a 4tb external drive connected to my laptop. I’ve synched it to the software. When I try to play a track, it says it’s unable to open an audio file for playback. I also noticed that exclusive audio access mode is disabled, even though when I check this in Windows, it says my device has exclusive checked off. I am using Kernel Streaming in Origin. I’m running Windows 10, if it matters. Any advice on what to do for this?
Dbug info:
Audirvana Origin 2.5.12 (20512)
Windows 10 (19045) with 32GB physical RAM
Connected account of : Chris Desjardins
Available network interfaces:
HPS Secure ({aac9cc44-3218-40f5-8c6e-23419a68f057}) is PUBLIC
Windows Defender Firewall status for this instance of Audirvana Origin
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Norton 360
AUTO: E:
Library database path: C:\Users\Chris Desjardins\AppData\Local\Packages\Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
E:
Deep Synch: yes
Scanning 2951/112621: E:\Allman Brothers Band, The\The Allman Brothers Band 1998 Japan promo box\Allman Brothers Band 1976 Wipe the Windows, Check the Oil, Dollar Gas (JPHCR-94008)\Wipe The Windows art 400 dpi\front complete.jpg
Listening on 10.3.13.6 on port 59608
UI theme: light
Font size: regular
My Music
Library
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 18024MB
Speakers (AudioQuest DragonFly Red v1.0)
Model UID:USB\VID_21B4&PID_0082&REV_0108&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{24b30832-2844-435c-91c9-3bffc79fc720}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Speakers (AudioQuest DragonFly Red v1.0)
Manufacturer: (Generic USB Audio)
Model name: AudioQuest DragonFly Red v1.0
Model UID: USB\VID_21B4&PID_0082&REV_0108&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{24b30832-2844-435c-91c9-3bffc79fc720}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x21b4
USB Product ID: 0x0082
Kernel Streaming capable
MQA Renderer device
Simple stereo device: No
Device #0: Speakers (AudioQuest DragonFly Red v1.0)
Device #1: Speaker (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0245&SUBSYS_103C875C&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ef2587ec-d36b-43bd-b973-b65d02ffb37c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
Yes, it happens no matter what I try. It worked a few days ago, and then just stopped.
Hi Chris,
Not on windows, macOS, but I had quite the same thing a while ago and don’t know if it’s possible on W…
I stopped the access by the finder to choose my files and connected the external volumes by “direct connection” using the ip address of the volume by mounting it.
Hope have been clear
Laurent
Hmmm… Not sure how to do this in Windows. I have to say I’m really disappointed. I absolutely LOVE how this software sounds - truly remarkable compared to others I’ve used. But if I can’t get it to work, there’s no point in having it. I tried it at home instead of at work to see if there was some sort of network blocking going on, but it doesn’t work on my home wifi either. I’m asking our IT guy to take a look tomorrow, so I’m hoping he can figure it out.
Does anyone think an uninstall and reinstall would work?
Please try this, it’s the first thing to do in such case.
