I am not sure if this problem has been solved but I have the same problem.
@ScottieA Please let me know what was the response from the Audirvana team.
For what it is worth here is the debug log from my side:
Audirvana Mac Version 1.6.4 (10604)
macOS 10.14.6 with 6144MB RAM
Bandwidth at 0dB = 96.2988%
Filter max length = 29551
Anti-aliasing = 85
Phase = 0%
SW volume control: ON
AUTO: /Users/user/Documents/Music
iTunes/Music library synchronization: last synchronized on Fri Sep 3 12:08:15 2021
Library database path: /Users/user/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 53796
LUCKIT LUCKIT USB 2.0 AUDIO OUT
Model UID:Luckit USB Audio 2.0:20A0:4143
UID:AppleUSBAudioEngine:Luckit :Luckit USB Audio 2.0:0330:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Sample rate limitation: 48kHz
Sample rate switching latency: 3s
Limit bitdepth to 24bit: ON
ID 0x27 Luckit USB 2.0 Audio Out
Manufacturer: Luckit
Model Name: Luckit USB 2.0 Audio Out
Model UID: Luckit USB Audio 2.0:20A0:4143
UID: AppleUSBAudioEngine:Luckit :Luckit USB Audio 2.0:0330:1
Preferred stereo channels L:2 R:1
Simple stereo device: No
Channel #0 :Stream 0 channel 1
Channel #1 :Stream 0 channel 0
Stream ID 0x28 2 channels starting at 1
12 virtual formats:
12 physical formats
Device #0: ID 0x3d Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x27 Luckit USB 2.0 Audio Out Manufacturer: Luckit Model UID: Luckit USB Audio 2.0:20A0:4143 UID: AppleUSBAudioEngine:Luckit :Luckit USB Audio 2.0:0330:1 Model Name: Luckit USB 2.0 Audio Out
