When I open Audirvana it will play. After playing an album, the next album selected brings message “Unable to open audio file” this has happened repeatedly since I downloaded new app. No problem prior to that
Audirvana Studio 1.7.2 (10702)
Windows 10 (19042) with 16GB physical RAM
AUTO: H:\Ripped music
Library database path: H:\Ripped music\AudirvanaDatabase.sqlite
Listening on fde0:932b:b48e:1:99c9:c1d8:c7b3:4f7 on port 54258
Max. memory for audio buffers: 3328MB
Local Audio Engine: WASAPI
Speakers (2- FOCAL ARCHE Audio 2.0)
Model UID:MMDEVAPI\AudioEndpoints
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{715c0aba-c962-4a4d-882b-b98cb7e4783d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Manufacturer: Microsoft
Model Name: Speakers (2- FOCAL ARCHE Audio 2.0)
Model UID: MMDEVAPI\AudioEndpoints
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{715c0aba-c962-4a4d-882b-b98cb7e4783d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Local devices found : 4
Device #0: Speaker/HP (Realtek High Definition Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{427fcfad-007d-4fd9-adab-5406464af6ec}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Speaker/HP (Realtek High Definition Audio)
Device #1: S2719DGF (NVIDIA High Definition Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{db2cfac0-0348-494e-af15-4957e998ead9}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: S2719DGF (NVIDIA High Definition Audio)
Device #2: Speakers (2- FOCAL ARCHE Audio 2.0) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{715c0aba-c962-4a4d-882b-b98cb7e4783d}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Speakers (2- FOCAL ARCHE Audio 2.0)
Device #3: Speakers (14- USB Audio Device) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{283c0d40-bd41-40ee-b2c4-c78df0e8a177}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Speakers (14- USB Audio Device)
