Hi everyone,
I’m using a Topping E30 DAC via USB with my Windows 10 laptop. I have followed all steps advised on other threads regarding this to no avail. I’m still unable to playback DSD although my DAC supports up to DSD512.
Here’s by debug info:
Audirvana 3.5.43
Sync list: 0 folders
Library database path: C:\Users\mirj\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4354MB
Local Audio Engine:ASIO 2 driver version 1280
Topping USB Audio Device
Model UID:Topping USB Audio Device
Device: 2ch 32bits Integer, 8 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Topping USB Audio Device Manufacturer:
Model UID:Topping USB Audio Device UID:Topping USB Audio Device
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Local devices found : 3
Device #0: foo_dsd_asio Manufacturer: Model UID: foo_dsd_asio UID: foo_dsd_asio
Device #1: Realtek ASIO Manufacturer: Model UID: Realtek ASIO UID: Realtek ASIO
Device #2: Topping USB Audio Device Manufacturer: Model UID: Topping USB Audio Device UID: Topping USB Audio Device
