Please help - I am streaming MQA files from tidal which are higher than 96khz but I am only able to get 96khz output. My DAC is a Khadas tone board which I am almost sure has been capable to do this before. See below the data from my configuration. When I play files that are in my hard drive, I am able to get the higher sample rates.
Thank you in advance as always.
Audirvana Mac Version 3.5.40 (3570)
macOS 10.15.6 with 4096MB RAM
Registered to JOSE BERMUDEZ
Per track: OFF
AU plugin #0: Effect - Voxengo Marvel GEQ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Sync list: 2 folders
AUTO: /Users/perro1965/Music/HDtracks
AUTO: /Users/perro1965/Music/THE AUDIOPHILIAC MA RECORDINGS SAMPLER
iTunes/Music library synchronization: last synchronized on Mon Aug 31 20:43:41 2020
Library database path: /Users/perro1965/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1024MB
Khadas Tone Control
Model UID:Khadas Tone Control:20B1:000A
UID:AppleUSBAudioEngine:XMOS:Khadas Tone Control:14100000:1
ID 0x29 Khadas Tone Control Manufacturer:XMOS
Model UID:Khadas Tone Control:20B1:000A UID:AppleUSBAudioEngine:XMOS:Khadas Tone Control:14200000:1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Device #0: ID 0x39 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x29 Khadas Tone Control Manufacturer: XMOS Model UID: Khadas Tone Control:20B1:000A UID: AppleUSBAudioEngine:XMOS:Khadas Tone Control:14200000:1
