I would like to get some clarification about the filter phase upsampling parameter setting when using SoX. The default settings (unless I’ve accidentally changed something) appear to be:
If I wanted to set the filter phase to perfectly linear, where would I put the slider?
The SoX command line parameter puts this at 50%:
-p 0-100 Any phase response (0 = minimum, 25 = intermediate, 50 = linear, 100 = maximum)
In Audirvana, the extreme right of the slider is labelled “Linear”, how do these two scales correlate? Should I set the slider to 50 or to 100, for linear phase?
