Seems I had to reinstall my license after the 1.3.8 (1064) Windows update - then I got a message that
there was an error logging into Tidal. I resent Tidal’s password and all my other Tidal connections now work with the new password. But not Audirvana. Suggestions?
If you have changed your TIDAL password, it may have taken sometime to replicate the new password.
you’ll then want to retry entering your TIDAL credentials in Audirvana now.
Thanks for the idea… it appears that is not the problem as the password was changed yesterday and today the same problem occurs. PS all my other connections to Tidal work fine with the new password.
