Upgrade Origin is Failing
I get the following error when upgrading. Any idea how to fix this problem?
Error updating System.Exception: Package failed updates, dependency or conflict validation.Windows cannot install package Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_2.6.3.0_x64__q3nymrkmej12j because this package depends on a framework that could not be found. Provide the framework “Microsoft.VCLibs.140.00.UWPDesktop” published by “CN=Microsoft Corporation, O=Microsoft Corporation, L=Redmond, S=Washington, C=US”, with neutral or x64 processor architecture and minimum version 14.0.33728.0, along with this package to install. The frameworks with name “Microsoft.VCLibs.140.00.UWPDesktop” curren : Windows cannot install package Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_2.6.3.0_x64__q3nymrkmej12j because this package depends on a framework that could not be found. Provide the framework “Microsoft.VCLibs.140.00.UWPDesktop” published by “CN=Microsoft Corporation, O=Microsoft Corporation, L=Redmond, S=Washington, C=US”, with neutral or x64 processor architecture and minimum version 14.0.33728.0, along with this package to install. The frameworks with name “Microsoft.VCLibs.140.00.UWPDesktop” currently installed are: {Microsoft.VCLibs.140.00.UWPDesktop_14.0.29231.0_x86__8wekyb3d8bbwe Microsoft.VCLibs.140.00.UWPDesktop_14.0.29231.0_x64__8wekyb3d8bbwe Microsoft.VCLibs.140.00.UWPDesktop_14.0.26905.0_x64__8wekyb3d8bbwe Microsoft.VCLibs.140.00.UWPDesktop_14.0.27629.0_x64__8wekyb3d8bbwe}
Hi @Indy33 , can you please check that the App Installer app you can find in the Microsoft Store is up to date?
