Persistent a UPnP playback problem on MacOS (latest) - Tidal.
Playback stops at the end of the track and the next track is not played.
Debug Info
Audirvana Studio 1.11.0 (11100)
macOS 12.2.1 with 32GB physical RAM
Connected account of : Eugene C
Phase minimum phase
AUTO: /Users/dirt/Music/Local Library
Library database path: /Users/dirt/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50005
Preferred device: JF LIGHT INDUSTRIES BOTIC7_192.168.2.8 Model UID:JF Light Industries Botic7_192.168.2.8 UID:uuid:1c120f2b-cf57-d8cc-efcf-38d26955142e
UPnP device at http://192.168.2.8:49152/uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/description.xml
ID 0x0 Botic7_192.168.2.8
Manufacturer: JF Light Industries
Model Name:
Model UID: JF Light Industries Botic7_192.168.2.8
UID: uuid:1c120f2b-cf57-d8cc-efcf-38d26955142e
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get::application/flac:*
http-get::application/x-flac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
Volume Control: dB
15 virtual formats:
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 0:00:43
CurrentURI: http://192.168.88.218:49153/audirvana/audio_32.wav
CurrentURIMetadata: <?xml version="1.0" encoding="utf-8"?>dc:titleBlocks</dc:title>mpdupnp:classobject.item.audioItem.musicTrack</upnp:class>upnp:albumChapters (Deluxe Edition)</upnp:album>upnp:originalTrackNumber10</upnp:originalTrackNumber>http://192.168.88.218:49153/audirvana/audio_32.wavdc:creatorAnchorsong</dc:creator>upnp:artistAnchorsong</upnp:artist>
nextURI: http://192.168.88.218:49153/audirvana/audio_34.wav
nextURIMetadata:
dc:titleDaybreak</dc:title>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/139e4ec0/449f/48f3/b956/5826e82716b6/640x640.jpg</upnp:albumArtURI>
upnp:originalTrackNumber11</upnp:originalTrackNumber>
PlayMedium: HDD
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Botic7_192.168.2.8 JF Light Industries https://opensourceprojects.eu/u/medoc/profile/ UPnP front-end to MPD UpMPD 42 https://opensourceprojects.eu/p/upmpdcli/code/ upmpdcli version 1.4.6 libupnpp 0.19.2 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/presentation.html uuid:1c120f2b-cf57-d8cc-efcf-38d26955142e urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/evt-urn-schemas-upnp-org-service-ConnectionManager-1 urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/urn-av-openhome-org-service-Info-1.xml /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/ctl-urn-av-openhome-org-service-Info-1 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/evt-urn-av-openhome-org-service-Info-1 urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/urn-av-openhome-org-service-Time-1.xml /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/ctl-urn-av-openhome-org-service-Time-1 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/evt-urn-av-openhome-org-service-Time-1 urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/urn-av-openhome-org-service-Volume-1.xml /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/ctl-urn-av-openhome-org-service-Volume-1 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/evt-urn-av-openhome-org-service-Volume-1 urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/urn-av-openhome-org-service-Credentials-1.xml /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/ctl-urn-av-openhome-org-service-Credentials-1 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/evt-urn-av-openhome-org-service-Credentials-1 urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/urn-av-openhome-org-service-Playlist-1.xml /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/ctl-urn-av-openhome-org-service-Playlist-1 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/evt-urn-av-openhome-org-service-Playlist-1 urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/urn-av-openhome-org-service-Radio-1.xml /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/ctl-urn-av-openhome-org-service-Radio-1 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/evt-urn-av-openhome-org-service-Radio-1 urn:av-openhome-org:service:Product:2 urn:av-openhome-org:serviceId:Product /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/urn-av-openhome-org-service-Product-2.xml /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/ctl-urn-av-openhome-org-service-Product-2 /uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/evt-urn-av-openhome-org-service-Product-2UPnP devices found : 2
Device #0: ID 0x0 Botic7_192.168.2.8 UID: uuid:1c120f2b-cf57-d8cc-efcf-38d26955142e Location: http://192.168.2.8:49152/uuid-1c120f2b-cf57-d8cc-efcf-38d26955142e/description.xml
Device #1: ID 0x0 APlayer Media Renderer UID: uuid:3CA50632-4E12-4865-B460-1D926BABBC75 Location: http://192.168.2.8:1869/
Max. memory for audio buffers: 16046MB
Local devices found : 3
Device #0: ID 0x42 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x38 D70s MQA Manufacturer: Topping Model UID: D70s MQA:152A:8750 UID: AppleUSBAudioEngine:Topping:D70s MQA:14700000:1 Model Name: Topping D70s MQA
Device #2: ID 0x2c Sonarworks Systemwide Manufacturer: SIA Sonarworks Model UID: com_sonarworks_driver_SonarworksDevice:Sonarworks UID: SonarworksEngine:0 Model Name: SIA Sonarworks Sonarworks Systemwide
