UPnP stops at end of first track playing. Audirvana Mac Version 1.5.7 (10507) macOS 11.5.0 with 16384MB RAM
I don’t have this issue at all with Audirvana Mac Version 3.5.46 (3576) on same machine playing to same UPnP renderer (Rygel)
Hello,
Same for me but randomely : sometimes it stops after a track (first or not), sometimes not. This issue was not in 3.5.x.
My free trial is now over
So i can’t even check if app updates have fixed this issue
I won’t be subscribing to Studio until i can read this this issue has been fixed, from user reports.
Until then UPnP with my 3.5.46 works fine for me and i see no reason to pay to upgrade to a broken subscription with Studio
I have randomly the same problem.
Playing to what UPnP renderer exactly?
Even with v1.9?
NAIM Unity 2 with V1.9.
I have not investigated that for the moment as it is a secondary set for me. (main set is working fine and do not involve UPNp. I just noticed it several times.
Edit:
@Antoine @8934fdsj
I just did a quick test with the last STING Album (24/48 if format matters). I have had 2 stops, and also a track skip before the end. All this occurs about 10s before the end of the current track. It looks like it is the moment when the next track is sended to the reader.
Hello @8934fdsj,
@Antoine, here is mine, I did retry this morning, I have had some stops ans some skips of track, all occuring at about 15s bbefore the end of the current track.
Audirvana Studio 1.9.0 (10900)
macOS 10.14.6 with 8GB physical RAM
AUTO: /Volumes/Multimedia/Music
Library database path: /Users/alaindevita/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 51258
Preferred device: NAIM AUDIO LTD. UNITI2-4286 Model UID:Naim Audio Ltd. Uniti2-4286 UID:uuid:5F9EC1B3-ED59-79BB-4530-0011F6A64286
UPnP device at http://192.168.1.39:8080/description.xml
ID 0x0 Uniti2-4286
Manufacturer: Naim Audio Ltd.
Model Name:
Model UID: Naim Audio Ltd. Uniti2-4286
UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6A64286
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: Yes
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/wav:*
http-get::audio/x-mpegurl:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/x-mpegurl:
http-get::audio/x_pm_flac:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
14 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:03:18
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Uniti2-4286 Naim Audio Ltd. http://www.naimaudio.com NaimUniti2 all-in-one audio player NaimUniti2 20-004-0002 https://www.naimaudio.com/product/naimuniti-2 0011F6A64286 uuid:5F9EC1B3-ED59-79BB-4530-0011F6A64286 123810928305556upc urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1 urn:schemas-dm-holdings-com:serviceId:X_HtmlPage /HtmlPageHandler/desc.xml /HtmlPageHandler/ctrl /HtmlPageHandler/evt http://192.168.1.39:80/index.asp urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:0011F6A64286UPnP devices found : 1
Device #0: ID 0x0 Uniti2-4286 UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6A64286 Location: http://192.168.1.39:8080/description.xml
Direct Mode audio path, buffer I/O frame size: 0
Device #0: ID 0x31 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Sortie intégrée
What kind of track you were playing when the issue occurred?
24/48
It’s a track from Qobuz or from your local library?
Local Library.
QNap NAS->Audirvana->NAIM Unity 2
