wimk
November 20, 2020, 5:29pm
1
Hi,
I installed Audirvana on Windows 10. My Minx Xi player is visible in devices - network. But I can’t select the player. Looks like grayed out…
Should it be possible to stream to a upnp enabled player like the Minx Xi ?
What’s the difference in devices between the DAC and network section ?
Thanks for any help !
Best regards,
Wim
Antoine
November 23, 2020, 9:11am
2
Hello @wimk ,
When you want to select your device, do you have a track playing? You need to Stop (square button) to be able to change the audio output.
wimk
December 17, 2020, 8:14pm
3
Hi Damien,
Sorry for the late reply, missed yours…
I’m not playing music when I want to select the device. I can select my headset or speakers in the dac section. In the network section, the Minx Xi is visible, but I’m unable to select it.
Best regards,
Wim
Antoine
December 18, 2020, 8:31am
4
Have you tried to do reset of your network setting of your Minx Xi?
wimk
December 18, 2020, 7:55pm
5
I switchen from wifi to wired. As far as I know, there´s no option on the Minx to reset the network setting.
In the Settings you’ll find the “Factory reset”.
wimk
December 24, 2020, 12:50pm
7
Did a factory reset, but now my Audirvana trial is expired …
Any way to extend this ?
Thanks,
Wim
