Using Audirvana Studio on MacBook Air 2020 through Qobuz to Ifi Zen Stream when I select an album to play it doesn’t play the first track. When I select track 2 it works and then I go back to track 1. I’m new to AS so any advice most welcome. That aside very happy with AS
Hello @agamantic ,
Hi Antoine this is what I got this morning trying to play a random track from an album. AS was switched on just before. Once all my albums appeared I selected one to play. Again it showed as if playing but no sound.
After you open the debug info, you have to right-click in a response of this message and select Paste. I can’t see all of your debug info only with this screenshot.
Audirvana Studio 1.10.2 (11002)
macOS Version 12.1 (Build 21C52) with 16GB physical RAM
Connected account of : Michael Lindsay
AUTO: /Users/michaellindsay/Music/Qobuz
Library database path: /Users/michaellindsay/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50244
Preferred device: IFI AUDIO IFI STREAMER Model UID:iFi audio iFi Streamer UID:uuid:72743e2c-31cb-831d-040f-fec42969cdab
Currently playing to UPnP device at 16 bits 44.1kHz
UPnP device at http://192.168.0.137:49152/description.xml
ID 0x0 iFi Streamer
Manufacturer: iFi audio
Model Name:
Model UID: iFi audio iFi Streamer
UID: uuid:72743e2c-31cb-831d-040f-fec42969cdab
2 available sample rates up to 48000Hz
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get::application/flac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
4 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:01:45
CurrentURI: http://192.168.0.245:49152/audirvana/audio_0.wav
CurrentURIMetadata: <?xml version="1.0" encoding="utf-8"?>mpddc:titlePrelude and Fugue in C Major, BWV 846: Prelude (Transcription for Bass Viol by Lucile Boulanger)</dc:title>upnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorLucile Boulanger</dc:creator>upnp:artistLucile Boulanger</upnp:artist>upnp:albumBach & Abel: Solo</upnp:album>upnp:originalTrackNumber1</upnp:originalTrackNumber>http://192.168.0.245:49152/audirvana/audio_0.wav
nextURI: http://192.168.0.245:49152/audirvana/audio_2.wav
nextURIMetadata:
dc:titleCello Suite No. 6 in D Major, BWV 1012: Allemande (Transcription for Bass Viol by Lucile Boulanger)</dc:title>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/cb/ya/urhva2u2nyacb_600.jpg</upnp:albumArtURI>
PlayMedium: HDD
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 iFi Streamer iFi audio https://ifi-audio.com The Audiophile Music Player iFi audio 1.0 https://ifi-audio.com 42 uuid:72743e2c-31cb-831d-040f-fec42969cdab image/png 64 64 32 /upmpd/icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upmpd/RenderingControl.xml /ctl/RenderingControl /evt/RenderingControl urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upmpd/AVTransport.xml /ctl/AVTransport /evt/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upmpd/ConnectionManager.xml /ctl/ConnectionManager /evt/ConnectionManager urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /upmpd/OHProduct.xml /ctl/OHProduct /evt/OHProduct urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /upmpd/OHInfo.xml /ctl/OHInfo /evt/OHInfo urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /upmpd/OHTime.xml /ctl/OHTime /evt/OHTime urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /upmpd/OHVolume.xml /ctl/OHVolume /evt/OHVolume urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /upmpd/OHPlaylist.xml /ctl/OHPlaylist /evt/OHPlaylist urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /upmpd/OHRadio.xml /ctl/OHRadio /evt/OHRadio /upmpd/presentation.html http://192.168.0.137:49152/UPnP devices found : 1
Device #0: ID 0x0 iFi Streamer UID: uuid:72743e2c-31cb-831d-040f-fec42969cdab Location: http://192.168.0.137:49152/description.xml
Device #0: ID 0x2c MacBook Air Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Air Speakers
This happens to me as well.
This debug worked fine actually played straight away so I’ll send another if it happens again.
Michael
The debug didn’t fix anything, it just provided Antoine information to help them in possibly solving the problem.
Are you using the latest firmware available for your device and have you made any change in the setting of the device in Audirvāna Studio?
Same problem this morning first track shows playing but no sound. Wish this was as easy as Bluos was:(
No plugin active
Listening on 127.0.0.1 on port 49497
Currently playing to UPnP device at 16 bits 48kHz
ID 0x0 iFi Streamer
Model Name:
Volume control: No
DLNA 1.5: No
2 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:03:15
CurrentURIMetadata: <?xml version="1.0" encoding="utf-8"?>mpddc:titleBroken Record</dc:title>upnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorVan Morrison</dc:creator>upnp:artistVan Morrison</upnp:artist>upnp:albumVersatile</upnp:album>upnp:originalTrackNumber1</upnp:originalTrackNumber>http://192.168.0.245:49152/audirvana/audio_0.wav
nextURIMetadata:
dc:titleA Foggy Day</dc:title>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/88/19/0060256711988_600.jpg</upnp:albumArtURI>
PlayMedium: HDD
Your device should be able to stream DSD tracks, can you check if you are in the proper streaming mode on your device and if you have changed this?
Correct I can use up to 48000, I don’t think my dac can process dsd but I’ll try it.
Latest firmware yes and yes I’ve made changes to the settings to limit to lossless
48/20 bit and MQA off
Dsd doesn’t work
Can you remove the limit?
Yes done that and music plays but will need to shut down and restart to see if it will play from start up which was the original issue
Seems to have fixed the issue, thanks. I’ll check in again tomorrow to confirm or otherwise.
Cheers Antoine
Hi Antoine,
I’m having issue with first 1/2 second of each track not playing if I skip to different tracks
If I let an album play 1st track has this problem but then the other tracks play ok
I’ll post my settings
Just paid my subscription so hope this is an issue that can be sorted. Seems a kind of buffering issue. Sometimes tracks take ages to load or load and don’t play and I need to reselect the track…
No plugin active
Listening on 127.0.0.1 on port 49197
UPnP device at http://192.168.0.137:49153/description.xml
ID 0x0 iFi Streamer
Model Name:
Volume control: No
DLNA 1.5: No
2 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI: http://192.168.0.245:49152/audirvana/audio_27.wav
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 iFi Streamer iFi audio https://ifi-audio.com The Audiophile Music Player iFi audio 1.0 https://ifi-audio.com 42 uuid:72743e2c-31cb-831d-040f-fec42969cdab image/png 64 64 32 /upmpd/icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upmpd/RenderingControl.xml /ctl/RenderingControl /evt/RenderingControl urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upmpd/AVTransport.xml /ctl/AVTransport /evt/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upmpd/ConnectionManager.xml /ctl/ConnectionManager /evt/ConnectionManager urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /upmpd/OHProduct.xml /ctl/OHProduct /evt/OHProduct urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /upmpd/OHInfo.xml /ctl/OHInfo /evt/OHInfo urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /upmpd/OHTime.xml /ctl/OHTime /evt/OHTime urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /upmpd/OHVolume.xml /ctl/OHVolume /evt/OHVolume urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /upmpd/OHPlaylist.xml /ctl/OHPlaylist /evt/OHPlaylist urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /upmpd/OHRadio.xml /ctl/OHRadio /evt/OHRadio /upmpd/presentation.html http://192.168.0.137:49153/UPnP devices found : 1
Device #0: ID 0x0 iFi Streamer UID: uuid:72743e2c-31cb-831d-040f-fec42969cdab Location: http://192.168.0.137:49153/description.xml
Max. memory for audio buffers: 15122MB
Hello @agamantic, can you reduce the maximum memory that Audirvāna Studio can use to 4000MB? After doing this, can you try to reproduce the issue?
Same problem at 4000MB skipping first 0.5 sec of track
Not playing whole album
Wifi ok
Ethernet streamer no previous issues
Getting pretty fed up with AS
As soon as Qobuz sort out issues with iFi I’m dropping this. Makes Bluos look amazing.
