I use macbookpro i5 8G ram, macos 11.7.6
audirvana studio 2.8.0
denafrips ares2 (now enyo)
When I set the sampling frequency to exceed 2X, the sound starts to be distorted. Is it a computer efficiency problem?
How are you managing your Audirvana output gain settings (Volume) ? … Try reducing the gain before upsampling… Upsampling will add dynamic range to the original file…
Please paste your Debug Info here, so folks can help the best possible… It is found here:
Settings–> My Account–> Help–> Debug Info
Audirvana Studio 2.8.0 (20800)
macOS 11.7.6 with 8GB physical RAM
Connected account of : spark wu
AUTO: /Users/spark/Music/音樂
iTunes/Music library synchronization: last synchronized on Wed Jan 10 16:06:34 2024
Library database path: /Users/spark/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 19596
Listening on 127.0.0.1 on port 49183
TIDAL: Connected as HiFi Plus
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
DENAFRIPS DENAFRIPS USB Audio V3.12 | A22FA1.6
Model UID:DENAFRIPS USB Audio V3.12 | A22FA1.6:152A:86EF
UID:AppleUSBAudioEngine:DENAFRIPS:DENAFRIPS USB Audio V3.12 | A22FA1.6:14100000:1
Active Sample Rate: 88.2kHz
Selected device:DENAFRIPS USB Audio V3.12 | A22FA1.6
Manufacturer: DENAFRIPS
Model name: DENAFRIPS USB Audio V3.12 | A22FA1.6
Model UID: DENAFRIPS USB Audio V3.12 | A22FA1.6:152A:86EF
UID: AppleUSBAudioEngine:DENAFRIPS:DENAFRIPS USB Audio V3.12 | A22FA1.6:14100000:1
USB Vendor ID: 0x152a
USB Product ID: 0x86ef
ID 0x43
12 available sample rates up to 1536000Hz
1411200
1536000
Audio buffer frame size : 27 to 4096 frames
DSD via PCM 1.0
Stream ID 0x44 2 channels starting at 1
24 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1411.2kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
24 physical formats
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
Device #0: ID 0x32 Built-in Output
Model UID: AppleHDA:123
Device #1: ID 0x43 DENAFRIPS USB Audio V3.12 | A22FA1.6
How much RAM is being used by Audirvana when you upsample to max device settings on your system? (Utilities, Activity Monitor memory tab) If it using more than 6GB I would reduce your preload buffer in setting/audio to +/- 4GB ram. With only 8 GB total your OS may be excessively swapping which could cause issues during playback.
The gain issue mentioned by @agoldenear in his initial post is a valid point also.
The playback pre-load memory allocation sticks-out as a commonly associated contributor to behaviors like you are experiencing…
I agree with @Djm1960’s suggestion regarding System memory vs playback-preload memory allocation… However, I differentiate, in suggesting to lower this allocation to 2GB.
You have the Upsampling parameters set to “Device Maximum” so, in the case of Audirvana Studio, the maximum PCM sample-rate output will be 1536kHz… this requires a lot of memory for calculations and packetizing for output transmission of the results… More available System RAM is better for overall playback performance, Especially, if your local Library is on the System drive…
I suggest using “Power of Two” upsampling for best performance… this will provide the mathematically correct results, best associated to the primary sample-rate…
Manage your gain structure…
Am I reading this right…
You’re saying that device maximum frequency refers to the output of Audirvana? Not the frequency of the connected device?
confused.
ID 0x4312 available sample rates up to 1536000Hz
1411200
1536000
This is the maximum PCM sample-rate of the DAC…
It’s really a problem of memory arrangement. Now the problem has been solved. Thank you for your advice.
Cool, got it.
Thanks.
