Upsampling DSD not working with HiFi Rose RS130
I have just bought a license for Audirvana Studio. I am connecting my PC to a HiFi Rose using UPnP.
Upsampling PCM files is working correctly, but I cannot upsample DSD and play it on my RS130.
I see that there is already a topic a couple of years old about this not working. Has this ever been fixed?
If not, how do I get a refund as Roon does not have this issue.
Hi @Conrad,
Are you using the latest firmware version from HiFi ROSE?
yes
I can play DSD64 files to the RS130 with upsampling disabled
Here is the debug info
Audirvana Studio 2.11.4 (21104)
Running on MacBookPro16,1
macOS 26.0.1 x86_64 with 16GB physical RAM
Connected account of : Conrad Winchester
Local network access: allowed
LOADING/DECODING:
Max audio buffer size: 13312MB
Internal EQ: OFF
Effect Plugins: NOT ACTIVE
AUTO: /Volumes/Data/Storage/InternalStorage
Sync folders at startup: YES
Sort and display order: en
Library database path: /Users/conrad/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Deep Synch: yes
Intializing
Fingerprinting track 913/6618 : /Volumes/Data/Storage/InternalStorage/Bob Marley & The Wailers/Legend The Best of Bob Marley and The Wailers/Disc 01/Bob Marley & The Wailers - Legend- The Best of Bob Marley and The Wailers - 01 05 - Buffalo Soldier.flac
Listening on
en0 IPv4: 192.168.86.33
en0 IPv6: fdfc:4ca2:a53d:61e4:1c5f:a36e:9bc2:a41b
on port 53672
Font size: regular
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: no
Active method: UPnP
Wi-Fi
Preferred device: [UPnP] ROSE - 90 Model UID:CITECH RS130 UID:uuid:dc4b65e8-4879-8630-ffff-ffffc0860aa6
Selected device:ROSE-35
Manufacturer: CITECH
Model name: RS130
Model UID: CITECH RS130
UID: uuid:b0eb9681-6093-0285-ffff-ffffc0860aa6
UPnP device at http://192.168.86.32:42391/upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/desc
ID 0x0
Volume control: Yes
Not automatically detected, user set to MQA Decoder
Raw DSD (msb)
UPnP set capabilities
Maximum PCM frequency set: 384000Hz
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: No
http-get::audio/flac:
http-get::audio/m4a:
http-get::audio/aac:
http-get::audio/3gpp:
http-get::audio/amr:
http-get::audio/ogg:
http-get::audio/mpeg:
http-get::audio/midi:
http-get::audio/x-midi:
http-get::audio/x-mid:
http-get::audio/x-wav:
http-get::audio/x-ms-wma:
http-get::audio/dsf:
http-get::audio/dsd:
http-get::audio/dff:
http-get::audio/x-dsf:
http-get::audio/x-dsd:
http-get::audio/x-dff:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB (0dB to 0dB)
28 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 00:05:12
CurrentURI: http://192.168.86.33:49152/audirvana/audio_f_14.wav
CurrentURIMetadata:
dc:titleHells Bells</dc:title>
dc:creatorAC/DC</dc:creator>
upnp:artistAC/DC</upnp:artist>
<upnp:author role=“Composer”>Angus Young</upnp:author>
upnp:genreClassic Rock</upnp:genre>
upnp:albumArtURIhttp://192.168.86.33:49152/audirvana/artwork_1_14.jpg</upnp:albumArtURI>
upnp:albumBack in Black</upnp:album>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Play
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 ROSE-35 CITECH HiFi ROSE RS130 1 http://4thline.org/projects/cling/mediarenderer/ uuid:b0eb9681-6093-0285-ffff-ffffc0860aa6 DMR-1.50 av-upload,image-upload,audio-upload image/png 48 48 32 /upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/msi.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/svc/upnp-org/AVTransport/desc /upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/svc/upnp-org/AVTransport/action /upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/svc/upnp-org/AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/svc/upnp-org/RenderingControl/desc /upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/svc/upnp-org/RenderingControl/action /upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/svc/upnp-org/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/svc/upnp-org/ConnectionManager/desc /upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/svc/upnp-org/ConnectionManager/action /upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/svc/upnp-org/ConnectionManager/event
UPnP devices found : 2
Device #0: ID 0x0 : Denon AVC-X6800H
UID: uuid:398bf2ea-4926-13f5-0080-000678d6ce98
Location: http://192.168.86.37:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Denon
Model name: Denon AVC-X6800H
Device #1: ID 0x0 : ROSE-35
Location: http://192.168.86.32:42391/upnp/dev/b0eb9681-6093-0285-ffff-ffffc0860aa6/desc
Model name: RS130
Local Audio Engine: CoreAudio
Device #0: ID 0x69 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #1: ID 0x3b Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Chromecast devices found : 3
Device #0: Workshop Wifi
Model name: Nest Wifi point
Device #1: Living Room display
Model name: Google Nest Hub
Device #2: SHIELD
Model name: SHIELD Android TV
And once you try to upsampling a PCM file to DSD64, nothing work?
Yes
OK, I have now installed Audirvana on a more powerfulLinux server. All is working well, apart from DSD upsampling.
I have configured custom PCM upsampling for PCM files and that works when PCM files play. However, I cannot see how to get it to upsample DSD files to DSD512 when they play. I have a collection of PCM and DSD files and am used to Roon or HQPlayer upsampling each format appropriately when it plays them. How do I do this in Audirvana.
You can’t upsample DSD tracks in Audirvāna, only PCM files can be upsampled to DSD.
If your output can support DSD, you will have the option in the upsampling settings of Audirvāna.
The processing overhead of DSD → DSD modulation introduces unacceptable playback latency for a ‘real-time’ high-performance digital audio player such is Audirvāna.
Roon does not support DSD → DSD modulation (up-sampling)
HQPlayer can do this in an offline process…
If you are dead-set on modulation of DSD files to 22.4MHz DSD512… Your best option is to do this offline using HQPlayer or one of these applications.
https://samplerateconverter.com
  • Suggestion on the macOS platform… lower your playback preload memory allocation to 4GB for best performance… You are allocating 13.3GB of your 16GB System RAM for playback preload memory.
Roon does do DSD upsampling - I currently have my Roon server upsampling all DSD to DSD512.
Hi @Conrad,
You are right, but Roon does that by resampling/downsampling the original DSD source to PCM inbetween. After that the PCM is resampled/upsampled to DSD512. The inbetween conversion to PCM in theory downgrades the quality of the resulting outcome. You can find that information/discussions in the Roon forum (also discussions about how HQPlayer upsamples DSD vs Roon).
As far as I know, Audirvana seems to have made the choice not to go that path. SoX and R8Brain (used by Audirvana) can only upsample PCM files. In this case you could consider to use an external program to upsample your existing DSD files to DSD512 files and then play them in Audirvana.
@Conrad
It is called ‘modulation’... The transmogrification/interpolation of DSD–>DSD uses a modulation algorithm to increase the sample-rate of the PDM file… Because of the size of the file(s), the processing overhead/latency needed to produce very high-quality interpolation/modulation output, is unacceptable for ‘real-time’ playback.
