Quick question, does anyone know where I can find the original 'factory" settings for the upsampling filters? I’ve spent a lot of time adjusting them and get the fact that I should use my ears to decide but I can’t find the original settings.
Whilst I’m here does anyone have any advice around upsampling into a non-oversampling dac please? I’m using a Mac Mini going into a Lab12 SE dac.
What is the point of these options? Assuming one has a decent dac to start with what improvements are claimed to be achievable by tweeking these knobs? Is it just up to us to try different settings and check for improvements or otherwise?
That is a complex subject and not easily answered. There are lots of pro’s and cons with upsampling in software (music player program on a pc) vs hardware (DAC). The processors in DACs tend to have not much horse power so generally use very simple and crude upsampling methods. The processor in a computer like a pc or Mac is usually much more powerful and can use more sophisticated methods and filters.
There are also lots of different algorithms to upsample/resample (for example those used by SoX and r8brain) and each have their own settings, filters etc. All off these exist because there is no ‘perfect way’ of upsampling.
Puristic audiophiles who don’t like upsampling tend to turn this completely off and want the source to be transported to the DAC unaltered (bit perfect). Others like to upsample and tinker with the different settings. There is no ‘better or worse’ here. It all boils down to taste and preference.
Suffice to say that a lot of people enjoy to use ‘audiophile’ software (like Audirvana, HQPlayer, Roon, Foobar, etc. etc.) because of these possibilities.
Andy Thanks for this input. Yes I kind of guessed that it would all boil down to personal taste and I suppose it also depends on the quality of users hifi separates and whether they feel their sound needs some tweaking. Cheers for posting the links.
Perhaps there are no standard setting as every ear and every hifi equipment is different. But nevertheless: factory setting should be restorable as a software option; at least they should be document in the help files.
So the settings above should be the default settings in 3.5.
In Audirvana Studio 1.12.2 I use r8Brain and never changed the parameters to SoX also.
So the default settings there are (not surprisingly the same as in 3.5):
There’s no relationship between any DSD bit rate, and any PCM sample rate. Any DSD bit rate can be converted (remodulated) to any PCM sample rate, and vice versa. DXD (352.8 kHz) and Very High Bit Rate PCM (384 kHz) are the highest professional PCM rates employed today. DXD started as an editing format developed by Philips and Merging Technologies.
DSD and PCM are completely different digital encoding standards.
PCM is a series of completely independent binary coded samples representing actual numerical arithmetic values of signal level at the time of the sample.
DSD is a modulated bit stream comprised of a population of (clock) bits whose density is proportional to signal level, and unlike PCM, DSD contains no numerical values. Recording in DSD 256 does not imply any PCM derivative of any sample rate.
With PCM, think of movie film made of individual stand alone frames, each containing a separate picture (or signal value) in a sequence of separate pictures.
With DSD, think of a picket fence with more or less pickets present, proportional to the original signal level.
The word “Upsampling” applies only to PCM to (another form of) PCM, which contains samples to be rate multiplied. Converting any DSD rate to another DSD bit rate involves remodulation, not simple multiplication and interpolation as with PCM to PCM.
…This article will provide insight into the differences between PCM and DSD signals:
Thank you for the reading tips @Agoldnear. So I know what to do this evening. I am just seeking a better understanding. Neither my equipment nor my ears most probably allow to hear any differences.
Ears are a factor by the way that is often neglected in reviews or tests!
It’s the setting that sounds the best to you in your playback scenario… nobody can give you an absolute value…
SoX algorithm:
Bandwidth: This indicates the limit of the low-pass filter as a percentage of the Nyquist frequency (half the sampling frequency). The filter’s slope is low at 74% and very steep at 99.5%. Make sure that this does not induce too much brightness (i.e., highs are too aggressive).
Maximum filter length, i.e., the amount of memory and CPU load, used by the oversampling filter. The default value is sufficient in most cases. It can be increased to achieve better quality when oversampling to very high frequencies (e.g., DSD oversampling)
Anti-aliasing: the level of suppression of the signal in the cut band of the low pass filter. Any frequency still present in the cut band gives artifacts from harmonics that end up in the output signal. Higher values of this parameter give better quality at the cost of a higher CPU load.
Phase: All low-pass filters have some level of overshoot. The steeper the filter slope, the greater the overshoots. How upsampling works in Audirvāna?
A reply a bit paternalistic don’t you think? I did not ask for the correct setting. I asked for the value that sets Linear phase because there’s a difference between the Audirvana implementation vs the SoX’s notes. So that needs clarification.
But no worries… I found it in Audirvana’s SoX’s tab footprint - it is 100.
I know what I want, but there’s nothing wrong in exchanging views on phase settings performance expectations… but no matter I know the math behind it and need no help.
You may like to know the convolution engine in Audirvāna uses r8Brain…
… We use the high-quality sample rate converter r8brain to adjust your impulse responses when playing a track whose sample rate doesn’t match your filters. https://audirvana.com/signal-processing-suite/
