Hi Damien,
Here we go, please find below.
Thank you and Kind Regards,
Zsolt
macOS 11.2.2 with 16384MB RAM
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SoX custom frequencies
Phase = 49
AUTO: /Users/zsoltboczen/Desktop/MusicCollection
Library database path: /Users/zsoltboczen/Desktop/MusicCollection/AudirvanaSync/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1998MB
Exclusive access: Disabled
Integer mode: Disabled
MM-1
Model UID:MM-1:19B5:0004
UID:AppleUSBAudioEngine:Bowers & Wilkins:MM-1:304:1
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 48kHz
Active Sample Rate: 48kHz
Sample rate limitation: 96kHz
Sample rate switching latency: 0.5s
ID 0x3b MM-1 Manufacturer:Bowers & Wilkins
Model UID:MM-1:19B5:0004 UID:AppleUSBAudioEngine:Bowers & Wilkins:MM-1:304:1
3 available sample rates up to 48000Hz
32000
Stream ID 0x3c 2 channels starting at 1
6 virtual formats:
6 physical formats
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:57 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x3b MM-1 Manufacturer: Bowers & Wilkins Model UID: MM-1:19B5:0004 UID: AppleUSBAudioEngine:Bowers & Wilkins:MM-1:304:1
