I hope someone can help me…My DAC has a display that shows the quality of the file that I’m playing. When I stream master quality files directly from Tidal, the DAC will show 88 or 96khz, however, If I use Audirvana to stream from Tidal, the DAC’s display will always show 44khz.
Am I not using the right Audirvana sound configuration? What should be the right way of setting it up? I have tried but nothing changes.
I am using a Mcbook pro and my DAC is a Topping D10.
