Is there a way to pin My Playlists to the left hand side column? The software only lets you make three shortcuts!
If you see the icon, click on it
in the playlist manager you will be able to pin it on the left and on the right using this:
Thank you for your speedy response. But I would like to close the additional window and show the playlists under the main left column
Is there a way to pin the playlist navigator without the editor?
