Hi, I have the Android app installed and would like to know if or how to use it to control the volume of Origin running on my imac. Can the volume be changed during playback at all, I get the message that Origin must be stopped to change settings, however this seems to be a very awkward way to control volume as you are just guessing at a setting. Please explain the process involved if it is possible to use on the fly. Thanks.
Hi @Dave_Love,
Can you please tell more about what triggered this? You changed the volume in the remote app? If so, how have you done this?
I will need to know more to try reproduce your issue and fix it with Damien.
