Yes… I’ve tried the software volume control… no difference at all.
Debug info for that selection if it helps.
Audirvana 3.5.40
SW volume control: ON
AUTO: C:\Users\Sonnie\Music
Library database path: C:\Users\Sonnie\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Maestro X9 Model UID:AudioControl Maestro X9 UID:uuid:34d7cce2-31a2-47b0-934b-032eae8d5c6a
UPnP device at http://192.168.1.135:34095/c20f3016-affb-4f5e-8930-3fc940c46b7b.xml
Maestro X9 Manufacturer:AudioControl
Model UID:AudioControl Maestro X9 UID:uuid:c20f3016-affb-4f5e-8930-3fc940c46b7b
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/flac:
http-get::audio/m4a:
http-get::application/ogg:
http-get::audio/wav:
http-get::audio/x-m4a:
http-get::audio/x-dsf:
http-get::audio/x-wav:
http-get::audio/mpeg:
http-get::audio/aiff:
http-get::audio/x-flac:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::text/xml:
http-get::audio/x-dff:
http-get::audio/x-aiff:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/x-aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Can play native DSD: Yes
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
NrTracks: 1
MediaDuration: 0:03:25
CurrentURI: http://192.168.1.144:49152/audirvana/audio_0_0.wav
CurrentURIMetadata:
dc:titlePretty Good Year</dc:title>
dc:creatorTori Amos</dc:creator>
upnp:artistTori Amos</upnp:artist>
upnp:genrePop/Rock</upnp:genre>
upnp:albumArtURIhttp://192.168.1.144:49152/audirvana/artwork_0_1.jpg</upnp:albumArtURI>
upnp:albumUnder the Pink</upnp:album>
nextURI: http://192.168.1.144:49152/audirvana/audio_1_1.wav
God
Tori Amos
Tori Amos
Pop/Rock
http://192.168.1.144:49152/audirvana/artwork_1_2.jpg
Under the Pink
2
object.item.audioItem.musicTrack
PlayMedium: NETWORK
<?xml version="1.0"?>
1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetMediaInfo_Ext
InstanceID
in
CurrentType
out
CurrentMediaCategory
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
RecordMedium
out
RecordStorageMedium
WriteStatus
out
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetCurrentTransportActions
InstanceID
in
Actions
out
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
X_DLNA_GetBytePositionInfo
InstanceID
in
TrackSize
out
X_DLNA_CurrentTrackSize
RelByte
out
X_DLNA_RelativeBytePosition
AbsByte
out
X_DLNA_AbsoluteBytePosition
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
TransportState
string
STOPPED
PAUSED_PLAYBACK
PAUSED_RECORDING
PLAYING
RECORDING
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
NO_MEDIA
TRACK_AWARE
TRACK_UNAWARE
string
string
UNKNOWN
DV
MINI-DV
VHS
W-VHS
S-VHS
D-VHS
VHSC
VIDEO8
HI8
CD-ROM
CD-DA
CD-R
CD-RW
VIDEO-CD
SACD
MD-AUDIO
MD-PICTURE
DVD-ROM
DVD-VIDEO
DVD-R
DVD+RW
DVD-RW
DVD-RAM
DVD-AUDIO
DAT
LD
HDD
MICRO-MV
NONE
NOT_IMPLEMENTED
SD
PC-CARD
MMC
CF
BD
MS
HD_DVD
RecordStorageMedium
string
UNKNOWN
DV
MINI-DV
VHS
W-VHS
S-VHS
D-VHS
VHSC
VIDEO8
HI8
CD-ROM
CD-DA
CD-R
CD-RW
VIDEO-CD
SACD
MD-AUDIO
MD-PICTURE
DVD-ROM
DVD-VIDEO
DVD-R
DVD+RW
DVD-RW
DVD-RAM
DVD-AUDIO
DAT
LD
HDD
MICRO-MV
NONE
NOT_IMPLEMENTED
SD
PC-CARD
MMC
CF
BD
MS
HD_DVD
string
NONE
string
CurrentPlayMode
string
NORMAL
REPEAT_TRACK
REPEAT_ONE
REPEAT_ALL
NORMAL
TransportPlaySpeed
string
1
1
string
WRITABLE
PROTECTED
NOT_WRITABLE
UNKNOWN
NOT_IMPLEMENTED
string
0:EP
1:LP
2:SP
0:BASIC
1:MEDIUM
2:HIGH
NOT_IMPLEMENTED
string
NumberOfTracks
ui4
0
512
CurrentTrack
ui4
0
512
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
LastChange
string
A_ARG_TYPE_SeekMode
string
ABS_TIME
REL_TIME
TRACK_NR
ABS_COUNT
REL_COUNT
X_DLNA_REL_BYTE
string
ui4
string
string
string
1
0
QPlay:2.1
Maestro X9
AudioControl
http://www.audiocontrol.com/
Maestro X9
6a2990b5-c237-4524-8f7e-989470d671bb
image/png
120
120
24
/LibRygelRenderer-120x120x24.png
image/png
48
48
24
/LibRygelRenderer-48x48x24.png
image/jpeg
120
120
24
/LibRygelRenderer-120x120x24.jpg
image/jpeg
48
48
24
/LibRygelRenderer-48x48x24.jpg
/xml/ConnectionManager.xml
/Control/LibRygelRenderer/RygelSinkConnectionManager
/Event/LibRygelRenderer/RygelSinkConnectionManager
/xml/AVTransport2.xml
/Control/LibRygelRenderer/RygelAVTransport
/Event/LibRygelRenderer/RygelAVTransport
/xml/RenderingControl2.xml
/Control/LibRygelRenderer/RygelRenderingControl
/Event/LibRygelRenderer/RygelRenderingControl
urn:schemas-tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/xml/QPlayDescription.xml
/Control/LibRygelRenderer/QPlay
/Event/LibRygelRenderer/QPlay
http://192.168.1.135:80/
DMR-1.51
5000
"Stimuli;Filtering"
UPnP devices found : 6
Device #0ZiP Hopper(Bedroom 1) UID: uuid:482e8dac-7fad-11df-afb7-71f07b5ecba2 Location: http://192.168.1.186:49200/device.xml
Device #1ZiP Hopper(Patio) UID: uuid:482e8dac-7fad-11df-afb7-711fa29acba2 Location: http://192.168.1.180:49200/device.xml
Device #2ZiP Hopper(Bedroom 1) UID: uuid:482e8dac-7fad-11df-afb7-71daddddcba2 Location: http://192.168.1.218:49200/device.xml
Device #3ZiP Hopper(Bedroom 1) UID: uuid:482e8dac-7fad-11df-afb7-71453918cba2 Location: http://192.168.1.143:49200/device.xml
Device #4ZiP Hopper(Living Room 1) UID: uuid:482e8dac-7fad-11df-afb7-7413e2d8cba2 Location: http://192.168.1.140:49200/device.xml
Device #5Maestro X9 UID: uuid:c20f3016-affb-4f5e-8930-3fc940c46b7b Location: http://192.168.1.135:34095/c20f3016-affb-4f5e-8930-3fc940c46b7b.xml
Max. memory for audio buffers: 5372MB
Local Audio Engine:WASAPI
Device #0: ARC AV AMP (Intel® Display Audio) Manufacturer: Model UID: ARC AV AMP (Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4f884a52-e58c-4cd6-bd18-67568c0d8db3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers / Headphones (Realtek High Definition Audio) Manufacturer: Model UID: Speakers / Headphones (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{8a521ea3-eef2-40c9-9fd6-db1157cb084b}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
