I would appreciate if I could use my iPhone’s hardware volume buttons to control the volume ! Some other apps can.
Also it’s unfortunate that the volume control bar, on iPhone, is not directly accessible. You have to be on the ‘En cours de lecture’ screen to see the volume control.
It’s bad because sometime you have to be very reactive to change the volume level !!!
